Blank screen 2c
jaskev
Blank screen 2c
Post by jaskev »
Dive today to 70m hour into dive and on ascent screen went blank.
have had a look at charging point and not obvious of any water ingress.
Any advice? :(
jb2cool
Re: Blank screen 2c
Post by jb2cool »
How much battery did the device have? the only time i have had similar (I'm on an OSTC Plus so not quite the same as this has a much smaller battery) is because the battery had not been used for a while so needed a bit of a recharge to boost this back up again.
Re: Blank screen 2c
First, try to hard-reset the unit.
- Connect to USB
-Toggle a reset with a (quite strong) magnet at the center of the screen
If the unit wakes up, make sure to recharge the unit (1) until the battery sign is green. All this assumes you have the 3.15 installed already. If not: Do so (2).
1: https://forum.heinrichsweikamp.com/view ... =2&t=16518
2: https://forum.heinrichsweikamp.com/view ... =2&t=22182
jaskev
Re: Blank screen 2c
Post by jaskev »
Unit now with Deep Ideas, Hopefully they can sort.
