Morning divers!
Got a problem with OSTC2c
I've installed on OSTC2c firmware 3.13
I've installed on Windows (7/64bit) Diver COmpanion 3.0 beta5
I've installed on Windows (7/64bit) Driver for FTDI (COM PORT) 2.12.18.0
Windows recognize the USB/COM port on COM3:
If I open Dive companion and set [COM3] [OSTC2 mk.2/2n/2c]
Then I click [Connect]
I got this error:
OSTC2c selected.
Connecting...
< block timeout (missing 256 bytes)
Not an OSTC Mk.2, 2n or 2c.
Cannot connect COM3: Not an OSTC Mk.2, 2n or 2c.
Errore: Cannot connect COM3: Not an OSTC Mk.2, 2n or 2c.
(If I di the firmware upgrade/downgrade it works perfectly... but the connect function doesn't work!)
MOREOVER: I've intalled DIVING LOG 6,0
I do the download funcion
Set [COM3] [Heinrichs Weikamp] [OSTC 2C]
When I click DOWNLOAD ...I got this error:
OSTC not found ...be sure taht computer is turned on and connected! (DC_STATUS-TIMEOUT)
DO YA THINK THAT THIS COMPUTER HAS DEFECTIVE ON USB/COM PORT COMMUNICATION???
Thanks in advance for your support!
IdroSub
OSTC2c COM port problem
Re: OSTC2c COM port problem
No, since you could update USB is definitely working.
Have you updated or downloaded this computer before?
ostc2 tek e ostc2 tr
Hi, I have an ostc2 tek and an ostc2 tr and I tried to update the firmware to version 3.07. it works but when i connect using companion 3.0 it doesn't let me set the name and logo. What can I do? Thanks
Lorenzo
Lorenzo
