OSTC Mk.2 Button Sensitivity
Posted: Tuesday 16. June 2020, 17:49
The set/menu button on my mk.2 is not very sensitive a lot of the time - needs a hard push. The other day, I used it when it was plugged into the charger and the button is really sensitive.
I was wondering if it's more sensitive because of the higher voltage, and whether the battery might be a bit tired and that's what is causing the unsensitive button. The battery info page says Cycles 287 (102) and lowest Vbatt: 3.931V.
Is replacing the battery likely to improve the button sensitivity?
