Silicon sleeve
Silicon sleeve
Do you know where can I get one of these sleeves:
[img]file.php?6,file=738,filename=OSTC3_silicon_sleeve.jpg[/img]
Thanks, Janos
Thanks, Janos
Re: Silicon sleeve
Made by Innodive, french seller for OSTC. But they do not sell it separately, I think (not seen alone on their internet site).
After that, it should possible to make such a protection with 3D printer or small silicon mold.
OSTC #12002 & #11150
Re: Silicon sleeve
Mailen them to ask if they seller them seperately.
They don't.
They don't.
Re: Silicon sleeve
Hi there.
I also checked @ innodive and you cannot get it separately.
You can make an outer shell with a 3D printer as I did for my OSTC Plus. If you are interested I could try and send you some photos of it.
Regards.
Regards.
Re: Silicon sleeve
I managed to get one from Innodive for my OSTC Plus (they requested a copy of the Heinrichs Weikamp invoice) ; not sure they still have the one for OSTC 3, smaller.
This protection is essential since the surface of OSTC with alloy body is very fragile and quickly marked with scratches.
Heinrichs Weikamp should propose it
Best regards.
Best regards.
Re: Silicon sleeve
It is essential, true. Especially for sidemount divers like myself.
Are you happy with the quality of the sleeve?
Delyan
Delyan
Re: Silicon sleeve
Hi Delyan,
Well, it was pretty hard to put in place, but after about 40 dives, no problem with this sleeve.
Note I use the rechargeable lithium ion battery, so I never have to remove the sleeve (I wonder how many times it could be removed / reinstalled before to cut itself).
Regards.
Regards.
Re: Silicon sleeve
Dear Didier,
Yes, that's the only thing that worries me a bit: after 20 or so dives on a liveaboard I may have plenty of salt captured between the device itself and the sleeve which can make the computer corrosion vulnerable.
I gave Innodive a shout yesterday and hopefully they would sell one sleeve to me too.
If you want to have the files for printing a 3D case, let me know. I would be happy to share them.
Delyan
Delyan
Re: Silicon sleeve
Hi Deylan,
Your proposal is very nice, but I'm not familiar with 3D printing. We have a printer at the office, but I suppose a special material is needed to print a supple sleeve ?
A friend of mine has an OSTC 3 and he would be happy to get such a sleeve.
Best regards,
Didier
Best regards,
Didier
Re: Silicon sleeve
Hi, Didier.
Sure. As long as both OSTC models are compatible, regarding size and positioning ot buttons.
No idea how to attach pics here but I can send you several photos of the case and you can show them to your friend.
Case model was designed by a 3D printing company and they chose the right type of material for printing it (both robust and flexible, so the case can fit tightly on the computer and meanwhile the device can be put in and taken out effortlessly). Printing itself costed me around 15 euro so I suppose it will not be much more expensive anywhere else. I have the name of the material too if your friend decides to ask a printing company to do it for him or her.
Files are in my mail box and they can be sent in no time.
Delyan
Delyan
Re: Silicon sleeve
Hi Deylan,
You can send me the files at didier@defay.fr. I'll keep you informed of what I able to do with them.
Thanks a lot.
Thanks a lot.
Re: Silicon sleeve
I could help with CAD files (of the computer) if this helps...
Re: Silicon sleeve
can you also share the files for the OSTC 2 from 2015?
Re: Silicon sleeve
> 2015?
Here you go.
> 2015?
Here you go.
Re: Silicon sleeve
Thanks!
BR,
(this adds some more points on my personal "Am i happy that i bought a OSTC?" score list)
BR,
Re: Silicon sleeve
Hi to all
I would also be interested in two silicone sleeves for OSTC plus.
Thanks in advance
Mario
Thanks in advance
Mario
Re: Silicon sleeve
Hi, Mario.
Innodive is the only place I know that offers silicone sleeves. Customer service there is good and they would usually reply quite promptly.
Matthias, your offer sounds very kind. Should you want to see the result from my humble attempt please let me know.
Delyan
Delyan
Re: Silicon sleeve
Do you have 3d case files from OSTC 2TR (2018). I would like to design and print a flexible TPU cover on a 3D printer
Thx.
Adrian
Thx.
Adrian
OSTC 2 TR 16906
Re: Silicon sleeve
Can you share the files of the OSTC3 please ?
Thank you per advance
Yoann
Yoann
Re: Silicon sleeve
Can you share the files of the OSTC2TR please ?
Adrian
Adrian
Re: Silicon sleeve
[quote=heinrichsweikamp post_id=18965 time=1526036817 user_id=148]
> 2015?
Here you go.
Adrian
> 2015?
Here you go.
Adrian
Re: Silicon sleeve
We're working on this... We have to remove some internal, technical details before posting the model files.
Re: Silicon sleeve
Gerade gesehen: Die Hülle(n) werden nun auch separat verkauft. Allerdings zu sehr abgehobenen Preisen für meinen Geschmack
https://www.innodive.com/store/miscelan ... -1527.html
Re: Silicon sleeve
Hi,heinrichsweikamp wrote: ↑Thursday 6. February 2020, 17:42 We're working on this... We have to remove some internal, technical details before posting the model files.
Attached is the OSTC 2017 (outer dimensions) as a CAD (STEP) file.
Hope this helps,
- Attachments
- ostc2_2017.zip
- (824.65 KiB) Downloaded 549 times
