After replacing the battery, Saft LS14500 3,6V and after the reboot, my OSTC Sport has passed directly to a dive mode. The depht is stuck to 45.1m and the duration starts to raise. And the battery status is display 0% which is wrong since it's a new one (see attached picture).
It's impossible to switch back to the menu and I can't use my computer anymore as it is stuck to the diving menu. I couldn't exit from it.
Could you help me to sort out this issue please ?
The firmware of my OSTC Soprt is 10.68
Thank you for your support.
Best regards.
Jean
OSTC Sport issue after replacing battery
Re: OSTC Sport issue after replacing battery
Hi Jean,
Did you try to remove the battery, wait a few seconds and then reinsert the battery ? Easy to do and it could work...
Yes I did it several times but the issue is still there unfortunately.
Could you assist please ?
Thank you.
Jean
Thank you.
Jean
62°C also look unrelaistic. The pressure sensor of the unit died and needs replacement at our place. Please email us in this case: info@heinrichsweikamp.com
