Helo,
I have OSTC 4. Was no problems and still believe is one of the best computers :) Still have small problems, hope I didn´t do any thing wrong. After last update I lost in computer possibility to change boton sensetivity and lost Helium MIX gases... :geek:
What I checked afret update i have everything what i need but those i lost. How I can get it back?
Do i need different update or I lost them forewer?
Thank you so much for help!!!!
Problems after update
Re: Problems after update
You installed the 1.5.4, right? There is, of course, still the trimix setup and the buttons menu in the SYS2 menu. And there are no plans to change this
I consulted my crystal ball and after staring a few hours into it we came up with the following here:
- You have an OSTC plus, not OSTC 4
- You run it on 1,5V batteries instead of the rechargeable 3,7V battery
- You accidentally installed the "hwOS sport" firmware instead of the "hwOS tech"
Right?
If yes:
a) go to the correct forum, please: viewforum.php?f=6
b) re-install the tech firmware with the App: viewtopic.php?f=6&t=14509
c) use the recommended 3,6V rechargeable battery in the OSTC plus
Right?
If yes:
what a f..ng idiot :lol: :lol: :lol: :lol: thank you so much... all pints after i did it wrong. Thank you for your advice. At specially about battery, thank you, as i didn´t know i need to use only rechargebla one.
Thank you again so much for help
No worries, thanks for the feedback.
