Hi
I have seen some tutorials on the net that PUA customize the OSTC with an inscription at the bottom of the screen.
I have not found how to do it, you know how to tell??
Andrea
Customization
Bardass
Re: Customization
You have to use jdivelog or ostc planner or ostc config on your personal computer
Bardass
marcasnow
Re: Customization
ah ok, then install the program.
which of these you have listed me is the best or at least as easy to use?
regards
Andrea
regards
Andrea
fbk3
Re: Customization
OSTC Planner is easy and has tons of other great features.
uchidechi
Re: Customization
how can I setup the language to French ?
DTR.Diver66
Re: Customization
Hello uchidechi,
here it is.
here it is.
uchidechi
Re: Customization
Merci DTR.diver66
J'ai un ostc 2N et votre fichier concerne le MK2...est ce compatible ?
De plus je m'attendais a devoir juste changer un parametre sous divinglog !
Le fichier que vous m'avez joint est exploitable comment ?
merci pour votre réponse !
DTR.Diver66
Re: Customization
the file for the Mk.2 and 2N is the same, it's just another case. To make changes you need a program like OSTC Planner or OSCT tools. OSTC Planner is also available in french. To change the language go to settings in the program. Here are the links:
http://ostc-planner.net/wp/
http://www.angermayr.net/download/ostctools.htm
