New V 1.30
New V 1.30
We have just uploaded a new 1.30 stable. After some continued issues with the timeout handling of the port we have now introduced some error messages for O2-Board related issues.
Additionally, a new CF38 is introduced. Setting this to "1" will show the divetime in Min:Sec for all divemodes.
A "Reset all" to reset all customs functions is recommended (but not required) to reset the new CF to it's default value of 0.
The new version can be downloaded here: http://www.heinrichsweikamp.net/ostc/en ... A2C491.htm
Wir haben soeben die neue 1.30 stable hochgeladen. Nach einigen hartnäckigen Problemen mit dem timeout verhalten bei Verbindungs-Unterbrechnungen zum O2 Board haben wir hier nun eindeutige Fehlermeldungen eingeführt.
Zusätzlich ist eine Neue CF38 eingeführt. Einstellung "1" zeigt dann in allen Tauchmodi auch die Sekunden bei der Tauchzeit an.
Ein "Reset all" zum Rücksetzen der Custom Functions ist empfohlen (aber nicht zwingend notwendig) um die neue CF auf den Defaultwert von 0 zu konfigurieren.
Die neue Version kann hier geladen werden: http://www.heinrichsweikamp.net/ostc/de ... A2C491.htm
Viele Grüsse/Best Regards,
divingcool
Re: New V 1.30
Post by divingcool »
hello Matthias
does this min and sec work on simulator?
simulating a dive is pretty long as it is in real time, while on some other comp.
the time is accelarated. Is this something that will change in the next future?
kind regards
robert
Re: New V 1.30
Yes, simulator will be improved in the future. Right now only real-time simulator is available.
divingcool
Re: New V 1.30
thanks Matthias for your fast answer.
appreciated
last question
on version 1.30
Re: New V 1.30
The simulator is working just as if the unit is diving. So you'll see the mins:secs in the simulator, too.
divingcool
Re: New V 1.30
bonjour Matthias
should i do any settings in the CF38 for min and sec.
i can sound like a dummy but it doesnt show on simulation :-(
thanks
robert
divingcool
Re: New V 1.30
bonjour Matthias
thanks
robert
Re: New V 1.30
Sure, CF38 has to be set to "1" to show the seconds in the divetime.
divingcool
Re: New V 1.30
thanks Matthias.
works fine now.
Anonymous User
Re: New V 1.30
Post by Anonymous User »
heinrichsweikamp Wrote:
> Hello,
> regards,
Try and change CF38 from 1 to 0. I was having some problems (maybe just me, or maybe not).
I gave up trying pretty quickly as I need it in 1 anyway, but better check it can be done.
