Failure ativazione OSTC2N
ling
Post by ling »
Hello, today during a dive, the OSTC2N has not started, the initial screen has remained the same even in the bottom .. then it was off .... I tried to turn it back on for a couple of times but mostrasempre and only the splash screen and then goes off again as if it did not read the pressure.
What should I do?
thanks
Lino
OSTC2N 2763
Re: Failure ativazione OSTC2N
Is it working when connected to USB?
ling
Post by ling »
yes
everything seems to work regularly, even when I was underwater switched on and I could easily browse through the menu but it is not activated in dive mode
Is CF00 on default?
If you turn on your OSTC you'll find on the top left the actual pressure. For example 975mbar... As soon as you start descending this pressure should increase. If not then maybe something with the pressure sensor is wrong...
ling
Post by ling »
CF00 >0,50m
show current pressure 505mbar
during the dive I brought it up to 8.5 bar but has not entered into dive mode
Lino
Lino, 505mbar? Where are you living?
ling
Post by ling »
yes ...yuo are right ..:-).....i live in Naples Italy.... on the sea ...:-)..... of corse the sensor doesen't work.
Could it be reset?
Lino
Try a reboot from the reset menu. But this doesn't explain why the unit did not switch to dive mode...
ling
Post by ling »
Hi, Matthias and Scubatino
I tried to reset CF, Gas, Deco, Decodata and do the reboot but nothing happened always gives me the error of 504mbar.
What should I do?
thanks
Lino
ling
Post by ling »
please answer me, if you must go in for service I would like to send it right away.
thank you very much
Lino
Send Matthias an ostc@heinrichsweikamp.com
ling
Post by ling »
thank you very much
Lino
ling
Post by ling »
hello,
sorry for the delay but I was on vacation and could not connect .....
endless thanks to Matthias for having admirably solved the problem of totally free replacement of the sensor in just 7 days from my communication ........ now my OSTC2N works perfectly.
best regards
Lino
