Hi There,
Am I right in thinking the charging circuitry is in the 2n, not in a USB wall charger, so it is safe to use a 1.5 Amp "charger", up until now I have always used a 1.0 Amp USB charger with my 2n.
In your opinion would using the higher Amp USB charger shorten the battery life ?
Safely Charging 2n
Dahab Boris
Safely Charging 2n
DB
OSTC 2n of course :-)
DB
Re: Safely Charging 2n
Charging current is set by the charging circuity inside the OSTC. Any USB charger with >=500mA will work just fine.
