OSCT Sport
I usually to the upgrade normaly.
This morning I tried to upgrade from 10.20 to 10.21.
During the "verify" time, i Had strange letter in front of verify (picture of the OSTC)
Then, a the end of the process, OSTC Companion send the message : "cannot upgrade : readback is different"
I tried a couple of time : same message
I tried to install older version : same message.
Any ideas ?
The 10.20 stays installed and look to be OK, but I m not sure it will during a dive
Companion says : cannot upgrade : readback is different
ericbarbey
ericbarbey
Re: Companion says : cannot upgrade : readback is different
Something new (and bad) happen : i cannot connect my Sport to Companion (last and older version).
Did a reset on Sport but nothing change.
Need help please.
Need help please.
Since this helped another user recently: Give subsurface a try.
https://subsurface-divelog.org/
Subsurface also can upgrade the firmware for the sport.
ericbarbey
After a few manipulation, I can connect to Companion.
I try with SubSurface but was not able to upgrade to 10.21, the process stop in the middle.
the strange message like in the photo of the first message appears again on the OSTC during the process.
Some more idea ?
Thank you
EDIT : move on --->
read.php?6,15681
(to concentrate message about the problem).
Some more idea ?
Thank you
EDIT : move on --->
read.php?6,15681
