OSTC Sport: New Firmware 10.22
The new OSTC Sport firmware 10.22 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
Changes since 10.18 (Changes since 10.21):
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =10.22
CHANGE: button hold-down will increase values or move the cursor automatically (again)
BUGFIX: Bluetooth communications issues
NEW: Option to rotate the screen
CHANGE: Custom GF high range increased to 45-95%
BUGFIX: Auto-Brightness clipped to lowest settings in bright sunlight on some devices
HeLiX
Re: OSTC Sport: New Firmware 10.22
Post by HeLiX »
Thanks Matthias!
Just purely out of interest, why end-of-dive-time < 10.22 instead of just leaving all with start-of-dive-time?
Because it's stored that way in the logbook "files". Changing the info in the logbook subsequently is not possible. So, older dives are shown with the end-of-dive time. Taking care of "midnight" or "new-year" dives was buggy and error prone. I have removed all this buggy code from the internal logbook now.
Mst
(:DRe: OSTC Sport: New Firmware 10.22
Post by Mst »
[size=large]DANKE!!!(:P)[/size]
[size=small]Jetzt fehlt (mir) nur noch die "lautere" Warnung bei zu schnellem Aufstieg[/size]8-)
Michoclo
Post by Michoclo »
My OSTC Sport (new firmware 10.22) indicate Battery Alarm :
Batt:0%
3,2V
My actual battery is a new 3,6 SAFT LS14500, and battery voltage appears to be declining rapidly... (td)
polar
Post by polar »
danke!
nach Problemen beim update von 10.20 auf 10.21 funktionierte das update von 10.20 auf 10.22 sofort.
grüsse
Continue here: read.php?6,16196
