New 3.13 Firmware
New 3.13 Firmware
Today, we released the 3.13 stable for the OSTC2 Series (2N/Mk.2/2C).
Changes since 3.00 (Changes since 3.11):
BUGFIX: Fix licence in German
1. Get new bootloader v2: http://heinrichsweikamp.com/service/software
2. Follow the step-by-step instructions: http://www.heinrichsweikamp.com/?id=117&version=en
Heute haben wir die Version 3.13 stable für die OSTC2 Serie (2N/Mk.2/2C) veröffentlicht.
1. Neuen bootloader v2 herunterladen: http://heinrichsweikamp.com/service/software
2. Die einfache Schritt-für-Schritt Anleitung befolgen: http://www.heinrichsweikamp.com/?id=117&version=de
Viele Grüße/Best Regards,
Re: New 3.13 Firmware
Vielen Dank euch! (tu)
Clownfish
Post by Clownfish »
Upgraded. Make sure you fully charge computer after upgrade as it resets the battery to 100%.
Sydney
Australia
OSTC 2 11528
Dahab Boris
Post by Dahab Boris »
Thanks for your continued support :-)
:)-D
DB
OSTC 2n of course :-)
PAOLO
Post by PAOLO »
Thanks for your continued support :-) !!!
(tu):)-D
Paolo
WG
Post by WG »
I gave it a couple of tries, but always get following error message when I try to start the process:
HeinrichsWeikamp Bootloader v2
Looking for http://www.heinrichsweikamp.net/autofirmware/ostc2.hex
Connected to \\.\COM4 at 115200
Searching for PIC ...
Found:18F 4685
what should I do differently?
Walter
OSTC 2531
WG
Post by WG »
fixed, tried it on another computer. All OK now. Thanks for your support
Walter
Hi Walter,
Even if you have solved this, the error indicates that the bootloader can not connect to our website. Maybe it was blocked from a firewall on the PC? Or, you did not had an active internet connection at this time.
Crickers
Post by Crickers »
Have just upgraded my 2N to 3.13, have there been any updates to the custom functions?
The latest CF list I can find is v2.94
Nick
OSTC 2n #4315
buk@nero
Post by buk@nero »
I have the same doubt. Are there new Custom functions, or do the ones for 2.94 apply?
Thanks for the update.
Crickers Wrote:
> Hi,
> Thanks
> Nick
Clownfish
Post by Clownfish »
No changes as far as I can see.
Sydney
Australia
OSTC 2 11528
Laurie_the_Knot
Post by Laurie_the_Knot »
The only change to Custom Function that I can see is in the implementation of CF31. Before V3.12 it showed battery voltage. At V3.12 and after it shows battery percentage (%). This represents the percentage of "on" time based on the setting of CF74.
Happy diving,
Laurie (OSTC2 #11454)
Lee Chenyu
Post by Lee Chenyu »
hi!guys,after update, the battery bar shows low(green ,not red )and blinking.
need to wait until the battery bar shows 100% ?
It's the second thread from the top (Marked: "FAQ: Battery blinking"...)
read.php?2,16518
Lee Chenyu
(:P) thanks
awanadive
Post by awanadive »
> CF74.
Hello, I was unable to find my answer: is it still possible with fw 3.13 to show the battery voltage?
Thank you!
AwanaDive
OSTC2N -- #5956 -- FW 3.13 EN
Theis Thorup
Post by Theis Thorup »
Hey Guys
Since updating to 3.13 my watch is running very fast? gaining 20 mins in a month or so?
Best,
Theis
edhowarth
Post by edhowarth »
Have a look at custom function CF48: Time offset/day
This Custom Function will correct the internal clock. The Value represents a number of seconds that will
be added to the clock at midnight.
Default value: 0:00s
Suggested range: -2:00s...+2:00s
Theis Thorup
Thank you but I imagine that would give an immediate offset and not add something like 30 secs a day?
edhowarth
Post by edhowarth »
No. It adds each day. At midnight.
I don't know what the maximum seconds it will do each day, but it'll be easy enough to test
Laurie_the_Knot
At midnight each day the software will decrement the clock by up to 120 seconds or increment it by 120 seconds.
Unfortunately there is a bug in the code which causes any attempt to increment by more than 59 seconds to decrement the clock.
So the practical range is -120 seconds (2:00 mins) to +59 seconds.
Happy diving,
Frank D
Post by Frank D »
Hi!
Where can I download this version's custom functions list ?
Frank (OSTC2N #4020)
jozzbee
Post by jozzbee »
Has there been any response on Frank's request?
I'm struggling too, finding the list of v3.13 C/F
jozzbee (OSTC 2c #7496)
The link is in the 2nd thread in this forum called " OSTC2 Custom Functions documentation": https://forum.heinrichsweikamp.com/read.php?2,8503 ;)
https://www.angermayr.eu/index.php/de/s ... s-download
Since the 2.94 BETA, no new CFs were added. So the docsument is still valid.
Isdahl
Post by Isdahl »
Hi
Im using an older OSTC 2N with firmware V2.02
Im just wondering if it straight forward to do a update to firmware V3.13
And if there is a step by step guide..
Seems that it can be tricky ?? And problem with USB drivers ??
Petter
