I am using the 1.38 beta version and have selected average depth but it did not register over two dives,it just stayed on 0.0m,have i done anything wrong?
Regards,Simon.
Ave depth does not function
Re: Ave depth does not function
Have you set the according CF to "1"?
Yes,as i mentioned the depth display remains on 0.0m ,it has replaced the temp readout,i used it in gauge mode over two dives and the display did not alter at all.I later ran two simulated dives one on a deco algorithum and the other in gauge mode,the ave depth function seemed to work on the deco algorithum dive but not in gauge.I really need it to work in gauge,have you any ideas?
I'll have a look at it. Maybe the routine is not implemented in Gauge mode...
Hi Matthias,i was wondering if you had come up with a soloution to this? i know you are busy but it would be appreciated.Thanks,Simon.
Hello again,i forgot to mention that if you get the ave depth working could you also implement a resettable stopwatch? dont know how difficult this would be for you but it would be a very useful feature when used in gauge mode etc,thanks in advance,regards,Simon.
I suppose u use the average depth for deco planning?
I'm intrested on how this works but I don't find a good essay about how to do this.
Do you have a link on how it works or can u explain it to me?
thanks in advance,
Steve
thanks in advance,
Steve
Steve
CMAS 2* Instructor
Belgium
CMAS 2* Instructor
Belgium
Steve,
here`s a link to a pretty good explanation of the Ratio deco.
http://www.yorkshire-divers.com/forums/ ... ained.html
Best,Kim
Best,Kim
