Hope someone can help with this!
I connect the ostc 3 via USB cable and open the companion, I see "starting ...done" on the ostc screen but when I click connect on the companion I get com port not found message no matter what number I put in for the port, I've searched this forum and consequently updated the ftdi drivers but to no avail.
Can anyone help?
OSTC 3 Com port not found issue
Re: OSTC 3 Com port not found issue
Do not try the COM ports randomly. Find out which one is the right one (Windows Device Manager -> Serial Ports -> The one which is only available when the OSTC is connected -> THIS one is the right one).
If it's not detected from the Companion in the COM-Port drop-down field, you can enter it manually ("COMx") in the field there.
thanks for the reply, i have replaced the usb lead for another and the computer does now show on device manager as "COM3" however, when trying to update via the companion I get several messages, "COM3 port not open" or "device is not an ostc3" or " unable to enter hwos service mode"
Matthias,
I just uninstalled the companion beta version and reinstalled the previous version 1.2 and it worked fine.
