Battery Power % for sport
divejy
Post by divejy »
Would like to know Does Sport detect how much battery left if I put a previous used battery (50% used) than wrongly select 100% new instead keep old % from menu.
My recently case is that I wrongly select 100% new battery and Sport using this % for afterward dive, I then have no idea how much battery left.
Jackson
Re: Battery Power % for sport
Hello Jackson.
For the Saft and other LS14500 it is hard to tell the capacity left in the battery without the proper user input at advance. Hence the % will be wrong unless very close to the end of the battery life when the voltage drops significantly and can be measured. I recommend not to use this setup without a proper working backup - especially for longer/deeper dives.
with kind regards,
Christian
