hwOS Tech: 2.20beta released
Attached to this post is the 2.20beta for all hwOS2 devices. It has several new features and some bugfixes compared to the 2.15: (New since 2.18beta)
NEW: Third and fourth logbook page per dive showing Gaslist and Setpoints in standard font size
BUGFIX: several minor graphic issues in logbook fixed
BUGFIX: Rare button issues in OSTC Plus hardware
BUGFIX: Compass sensitivity for newer models
BUGFIX: PSCR mode showed bailout gaslist instead of diluent gaslist
BUGFIX: PSCR mode "Better Gas" showed bailout gases instead of diluents
NEW: More customviews in surface mode for PSCR mode
NEW: Last Dive customviews in surface mode with divetime, depth and interval
BUGFIX: Reset to MOD in Diluent Menu did reset Setpoint change depth
NEW: Two ppO2 max settings. One for travel/bottom and one for deco gases
BUGFIX: Lost Diluent now possible in CCR and PSCR mode
NEW: ppO2 blinks in sensor mode when min/max boundaries are hit
CHANGE: Show actual GF (Not relative) in custom views in dive mode
BUGFIX: Do not check ppO2 for disabled gases
CHANGE: Apply safety margin parameters to both models (GF and non-GF)
BUGFIX: Impossible fixed-ppO2 (e.g. 1,6bar in 3m) used for tissue calculations
BUGFIX: Menu tree cleaned up (Exited to CCR menu from simulator settings)
BUGFIX: Do not show GF in divemode for non-GF deco mode
BUGFIX: Skip MOD Test for CCR in Sensor modes (OSTC cR and OSTC3 only)
CHANGE: Swap positions of ppO2(O2) and ppO2(Dil) in customview 10 on screen: "left = lean" and "right = rich"
BUGFIX: A wrong configured gas was suggested as "Better gas" on the configured depth even if this resulted in a ppO2 high or low condition
BUGFIX: O2 as diluent in CCR caused wrong calculations (Deco, EAD, END) in less then 6m depth
BUGFIX: Ignore "Toggle GF" Menu entry (in divemode) when using the non-GF deco mode
BUGFIX: Minor dive mode layout fixes in CCR Mode
CHANGE: Minor German language fixes
NEW: Warning for Diluent beeing out of safe ppO2 range in CCR modes
NEW: New Customview 9 in OSTC cR or OSTC3 shows mV readings after Sensor calibration
Weekend is coming, so please post some feedback on Monday ;)
Re: hwOS Tech: 2.20beta released
In 2.20beta from Aug.17th there is a bug in the displaying of the switch depths of the CCR setpoints. Switching does work, but instead of the configured switch depth there is "----" shown for setpoint x when the OC gas x is configured as something different from a deco gas. A bugfix has been identified and is under way (sent to Matthias). In the mean time, if you want to stay with 2.20beta and need to edit the switch-depths of setpoints, you can do so by temporarily configuring the OC gas with the corresponding number to type "deco".
br
I'll post another Beta in the next days that fixes this "Setpoint Change Depth" Bug.
Kehrmaschine
Post by Kehrmaschine »
Hi guys
Is this Beta stabile enough? Just preparing for my holiday starting tomorrow, wondering if I shall update or leave th V 2.15.
Mario
you shoud take the hex from the bitbucket Repository, it is the latest and best Firmware so far and contains some intermediate fixes introduced during the last days.
I'll post another beta tomorrow morning. I'd recommed using this one instead then.
Continue here: read.php?6,18127
