NEW OSTCTools for Android - Release
there is a new App with the OSTCTools.
HWOSConfig for Android.
What is implemented:
-Personalizing (setting of Customtext)
-Firmware update for HWOS OSTCs, Tech and Sport.
Supported OSTCs:
-OSTC 2 (new)
-OSTC Sport
-OSTC 3 (April 2015 and later)
-OSTC plus
I will add more features to the App step by step.
But due to the Bluetooth problems that some users have, i decided to release this Alpha version. With my testdevices firmware upgrade works like a charm.
Permissions:
the App needs
-Read/write access on the device
-Bluetooth access
-access to the internet.
There are no ads, and no data where collected.
Step by step instructions:
Install the App from Google
https://play.google.com/apps/testing/eu ... hwosconfig
-Accept permissions (only once after installation
Select your OSTCType (HWOS Tech or HWOS Sport) and click on download to get the latest firmware.
When you wipe to the right, you can see the history of changes file, provided with the firmware.
-Switch Bluetooth on your OSTC on.
-Go to Android settings, search and connect your OSTC.
-In the App select your OSTC from the combobox (make shure Bluetooth is on)
-click "CONNECT"
The type of the OSTC will be automatically detected and set in the combobox.
-check the type of the OSTC in the combobox, if neccessary change it.
(my OSTC Plus with Tech firmware tells me that it is a sport version, but it isn't, i have to clarify this with matthias)
After connection there is a line shown below the Download Button that tells the Identity of the OSTC (type). Plus users can mail me, or post the line here, together with te type of ostc (tech or sport).
-make shure you have a firmware version selected.
-click on "UPLOAD"
-be patient
Custom Text:
-Select your OSTC in the App
-Click on "CONNECT"
-Click on "CUSTOM TEXT"
-Set the text
-Click "OK"
-Click "DISCONNECT"
Have fun
Please give feedback per mail or here in the thread.
* Now in German
es gibt eine neue App bei den OSTCTools.
HWOSConfig für Android.
Was ist implementiert:
-Personalisierung (setzen von Customtext)
-Firmware update für HWOS OSTCs, Tech und Sport.
Unterstützte OSTCs:
-OSTC 2 (neu)
-OSTC Sport
-OSTC 3 (April 2015 und später)
-OSTC plus
Ich werde die App weiter ausbauen und weitere features implementieren,
aber wegen der vielen Probleme die manche mit Bluetooth mit Win oder Mac haben, habe ich entschieden diese Alpha Version freizugeben.
Mit meinen Test OSTC's funktioniert der Firmware update absolut problemlos.
Rechte:
die App benötigt
-Lese/Schreib Zugriff auf dem Smartphone (zum ablegen der Firmware)
-Bluetooth Zugriff (Verbindung mit OSTC)
-zugriff zum Internet. (Download der Firmware)
Keine Werbung und es werden auch keine Daten erfasst.
Schritt für Schritt Anleitung:
Installation der App von Google
-Permissions erlauben (nur einmal nach ersem Start)
-Einstellen des OSTC Typs (HWOS Tech or HWOS Sport) und klick auf "DOWNLOAD" um die aktuelle Firmware zu laden. it einem Wisch nach rechts wird die History, die mit der Firmware kommt angezeigt.
-Auf dem OSTC Bluetooth einschalten
-In den Android Bluetooth Einstellugnen, nach dem OSTC suchen und verbinden.
(muss nur einmal gemacht werden)
-In HWOSConfig den OSTC in der Auswahlbox (Bluetooth) auswählen.
-Vergewissern das Bluetooth am OSTC noch an ist.
-Klick "CONNECT"
Der OSTC Typ wird automatisch ermittelt und die Auswahlbox "OSTC Typ" entsprechend eingestellt.
-überprüfe den Typ in der Auswahlbox, falls nötig ändern.
(mein OSTC Plus mit Tech firmware ist der Meinung das es ein Sport ist, ist er aber nicht, ich muss das mit Mathias klären)
Wenn der OSTC verbunden ist, sthet unter dem Download Button eine Zeile mit der OSTC Identity (der Typ). OSTC Plus Besitzer können mir diese Zeile bitte zusenden oder hier posten. Bitte auch posten wenn andere OSTC falsch erkannt werden. Zusammen mit dem richtigen Typ.
-überprüfe ob eine Firmware ausgewählt ist
-klicke "UPLOAD"
-abwarten und Tee trinken
Personalisieren/Custom Text:
-Bluetooth am OSTC einschalten.
-OSTC in the App auswählen
-Klick auf CONNECT
-Klick auf "CUSTOM TEXT"
-Text einstellen
-Klick "OK"
-Klick "DISCONNECT"
Viel Spass.
Bitte um Rückmeldungen per Mail oder hier im Thread.
Regards/Grüße
Supported OSTCs:
-OSTC 2 (new)
-OSTC Sport
-OSTC plus
Permissions:
the App needs
-Bluetooth access
-click "CONNECT"
-click on "UPLOAD"
-be patient
Custom Text:
-Click on "CONNECT"
-Set the text
-Click "OK"
-Click "DISCONNECT"
Have fun
* Now in German
Unterstützte OSTCs:
-OSTC 2 (neu)
-OSTC Sport
-OSTC plus
Rechte:
die App benötigt
-Klick "CONNECT"
-klicke "UPLOAD"
-Klick auf CONNECT
-Text einstellen
-Klick "OK"
-Klick "DISCONNECT"
Viel Spass.
Regards/Grüße
Re: NEW OSTCTools - Alpha TEST for Android
New Alpha 1.0.2 uploaded, fixes some Timeout problems at firmware checking with OSTC2.
Neue Alpha 1.0.2 hochgeladen, Timeout Probleme beim Firmware prüfen mit OSTC2 sollten behoben sein.
Regards / Grüße
Regards / Grüße
Hallo Rob,
Das Tool ist wirklich sehr praktisch. Sogar für uns hier in der Produktion vereinfacht sich das Updaten jetzt. Funktioniert 1a!
Vielen Dank!
Vielen Dank!
There were crashes with some devices.
I uploaded a new version to fix these crashes.
Can one with:
Xperia XZ
Galaxy S7
LG G6
Pixel
Mate 9
Moto G4 Play
Please retest version 1.0.4
thank you!
Es gab ein paar Abstürze mit einigen Geräten.
Kann bitte jemand mit
Xperia XZ
Galaxy S7
LG G6
Pixel
Mate 9
Moto G4 Play
Die Version 1.0.4 ( aktuell im Playstore ) nochmal testen
Danke!
Grüße
Can one with:
Xperia XZ
Galaxy S7
LG G6
Pixel
Mate 9
Moto G4 Play
thank you!
Xperia XZ
Galaxy S7
LG G6
Pixel
Mate 9
Moto G4 Play
Danke!
Grüße
Klasse. Nachdem ich leider immer wieder mal ein kleines "connect" Problem mit win10 habe, bin ich von der App voll überzeugt. Zudem besteht jetzt auch die Möglichkeit im Ausland seinen Comp oder halt zu jeder Zeit, ohne große Komplikationen upzudaten.
Selbst wenn die App noch in der Beta oder Alpha Phase ist, finde ich sie sehr gelungen.
Leicht und intuitiv zu bedienen.
Was ist noch geplant?
Gruß und nochmal Danke
Markus S.
OSTC+ #15527 (OSTC2 new generation)
open circuit diver
germany
open circuit diver
germany
Hallo Rob,
Datum/Uhrzeit stellen (Automatisch bei Update oder bei Connect) wäre noch nützlich. Außerdem natürlich die Sprachoptionen bei der TECH Variante. Dafür werde ich neue Permalinks anlegen wo dann eben automatisiert immer die Stable in den verschiedenen Sprachen hinterlegt ist.
Die Funktionalität von "hwOS Config" wäre dann der nächste Wunsch. Also die Möglichkeit auf die OSTC Settings Einfluss zu nehmen.
Hallo zusammen,
bin gerade frisch dem Walchensee entstiegen
All das ist geplant.
Das ALPHA kommt daher weil ich es so schneller bei Google hochladen konnte.
Die Vorbereitungen eine App bei Google einzustellen kosten fast mehr Zeit als das Programmieren selbst, aber das ist jetzt fertig.
Als nächstes kommt Uhrzeit, Button Reset, und OSTC4 Firmware upload.
Dann mache ich mich an die Einstellungsmöglichkeiten für die Firmware.
@Matthias, das mit den Sprachen für die Permalinks ist gut. Sag Bescheid wenn diese hinterlegt sind. Eventuell kann man auch die Sprache im Dateinamen hinterlegen.
ostc3_firmware_DE.hex
ostc3_firmware_EN.hex
Wenn das alle Update-Programme einbauen sollen/können/müssen:
hwos-sport.hex
hwos-tech-DE.hex
hwos-tech-EN.hex
ostc4-tech.bin
und so weiter ...
Grüße
hwos-sport.hex
hwos-tech-DE.hex
hwos-tech-EN.hex
ostc4-tech.bin
und so weiter ...
Grüße
Hallo Rob,
Hier die neuen Permalinks (Die alten gehen natürlich bis auf weiteres auch):
hwOS Sport:
www.heinrichsweikamp.net/autofirmware/h ... are_DE.hex
www.heinrichsweikamp.net/autofirmware/h ... are_EN.hex
www.heinrichsweikamp.net/autofirmware/h ... are_IT.hex
www.heinrichsweikamp.net/autofirmware/h ... are_FR.hex
www.heinrichsweikamp.net/autofirmware/h ... ngelog.txt
hwOS Tech:
Für mehrsprachige Versionen sind die Dateien hinter den Links dann jeweils identisch. Hinter den "Sport" Versionen z.B. liegt vier Mal die gleiche HEX Datei. Zumindest solange die Viersprachigkeit dort fortgeführt wird...
hwOS Sport:
hwOS Tech:
Guten Morgen,
vielen Dank für die App. Sie funktioniert mit dem Samsung S8 und dem OSTC 2, Sport SW super, mit dem Lenovo Yoga Book allerdings nicht. Beim YB wird der Computer zwar erkannt, der Download bricht allerdings entweder sofort, spätestens jedoch nach 1% ab.
Harry
Harry
Ich habe gerade gesehen, dass die App versucht (?) hat, den Changelog mit herunterzuladen. Ich fände eine Funktion super, mittels der ich mir den aufrufen kann (oder habe ich da was übersehen?)
Harry
Harry
"Wisch" mal nach rechts. Dann taucht es auf...
Funzt, vielen Dank
Harry
Harry
mit welcher softwareversion hast du das Lenovo getestet?
Ich sehe keinen Crash bei Google.
Grüße
Grüße
Hallo zusammen,
ich habe gerade eine neue Version bei Google eingestellt.
Wenn diese funktioniert und nicht all zu viel Mecker kommt,
beende ich den Alpha Test und mach ein Release draus.
Neu in dieser Version
Neu: HWOS-Tech Firmware mehrsprachig
Neu: Übersetzung der GUI ins Deutsche
Neu: Datum und Uhrzeit stellen
Neu: Buttons bei OSTC4 auf Defaultwerte setzen
Neu: Einstellungen Dialog - Datum Zeit Synchronisation bei Verbindungsaufbau
Neu: Dialog zur Sprachauswahl der Tech Firmware vor Download
Neu: Benutzeroberfläche reorganisiert
Bugfix: Absturz wenn Verbindung zu OSTC4 beendet wird gefixt.
Info: Dateinamenskonventionen für Firmware Dateien geändert.
i just lauched a new ALPHA Version in Google Playstore.
If this Version works, and not to many complains rise,
i will stop the ALPHA Test and create a release.
New: Multi Languages for HWOS-Tech
New: Translation German
New: Date time sync
New: Button reset for OSTC4
New: Settings - sync on connect
New: dialog to choose firmware language before download
New: GUI reorganized
Bugfix: crash when disconnecting OSTC4 solved.
Info: due to the firmware languages i changes the filename conventions.
best regards
New: Date time sync
best regards
Guten Morgen,
ich habe mit der (seit gestern Abend) glaube ich vorletzten Version getestet. Die Nummer weiß ich nicht mehr, ich habe die unmittelbar gezogen, nachdem dieses Topic eröffnet worden ist. Die App ist auch nicht abgestürzt, lediglich das Übertragen der Firmware auf den OSTC hat nicht geklappt. Ich teste neu, sobald eine neue Firmware verfügbar ist und achte dann mehr auf die Details. Brauchst Du bestimmte Daten?
Harry
Harry
Eigentlich reicht mir die Versionsnummer.
Aktuell ist die 1.0.5. Sonst suche ich unter Umständen längst gelöste Probleme.
Grüsse
Grüsse
> Mecker kommt,
> draus.
Kein Gemecker, sondern eher ein grundsätzliches Problem: Das angezeigte OSTC Modell stimmt nicht immer. Was nicht überrascht, kannst Du ja zwischen OSTC2 und OSTC Plus per Software nicht unterscheiden. Da dort alle Hardware-Features identisch sind (Batterie-Management-IC, Piezo-Schalter, Ambient light sensor, BLE Module) kommt natürlich auch das gleiche "Hardware flag byte" für Dich raus...
> Mecker kommt,
> draus.
Hi Rob,
ich hab nen OSTC2 (red buttons) und habe heute mal Deine neue Version ausprobiert.
Soweit funktioniert bei mir alles, bis auf den time setter.
Da ich nicht die Verhaltensweise kenne, was es tun sollte, kann ich nur sagen das bei onklick eine Aktion stattfindet (Button wird kurzzeitig dunkelblau) aber mehr geht nicht hervor. Sollte im Hintergrund die Zeit gesetzt werden, fände ich es schön, wenn ein kleiner Infotext wie zb. "Ortszeit gesetzt!" ausgegeben wird, damit man auch erkennen kann ob was passiert ist.
Gruß und nochmal Danke für die App
Markus S.
open circuit diver
germany
open circuit diver
germany
Zeit/Datum setzen geht hier einwandfrei.
Rob, vielleicht noch mit dem "0x6E" OSTC Befehl kurze Rückmeldungen auf dem OSTC anzeigen lassen?
Gute idee,
Schau ich mir an.
Grüsse
Schau ich mir an.
Grüsse
Hi Rob,
habe gerade mit der Version 1.0.5 auf meinem Samsung TAB 3 getestet.
Funzt, auch der Download läuft problemlos durch.
Einige kleine Anmerkungen:
1) Gibt es beim Button "Personalisieren" irgendwie die Möglichkeit die aktuell schon eingespielten Daten abzurufen? Vorher hat Divemate Daten eingetragen, der Dialog zeigt aber nichts an.
2) Ich schliesse mich meinen Vorrednern an, dass beim Zeit setzten wirklich eine Rückmeldung fehlt, ob und was passiert. Wenigstens ein Dialog "Uhrzeit und Datum wurden auf 31.01.2018, 14:43 gesetzt" nach Abschluss der Aktion fände ich angenehm.
3) Die Icon's finde ich leider nicht selbsterklärend. Läßt sich da etwas Text ergänzen? Z.B. solange ich den Finger auf dem Button liegen habe als Ballon-Hilfe daneben?
Super Tool, vielen Dank
PS: Planst du auch eine iOS Version?
Olaf
Olaf
ich habe gerade nochmal eine Version bei Google hochgeladen.
Vorweg, die einzelnen OSTC werden nicht richtig erkannt,
ist so.
Folgende Änderungen sind erfolgt:
Neu: Button tooltips wenn button lange gedrückt wird
Neu: Button reset for HWOS computers
Neu: Rückmeldung bei Tastenempfindlichkeit zurücksetzen (Gerät and OSTC)
Neu: Rückmeldung beim Setzen von Datum und Uhrzeit (Gerät and OSTC)
Neu: Rückmeldung beim Personalisieren (Gerät and OSTC)
Bugfix: auslesen des Customtextes überarbeitet
Bugfix: Customtext Dialog Aussehen und Verhalten überarbeitet
Bugfix: Unnötigen Refresh Button entfernt
there is an new Version of HWOS Config at Google playstore
First, the OSTC type can't properly detected.
Here are the changes in Version 1.0.6
New: Button tooltips when longpress
New: Button reset for HWOS computers
New: Responsemessage at buttonreset (Device and OSTC)
New: Responsemessage when setting date and time (Device and OSTC)
New: Responsemessage when setting customtext (Device and OSTC)
Bugfix: reading customtext from ostc
Bugfix: Customtext dialog design and behaviour
Bugfix: unneccessary refresh button removed
Grüße/Regards
ist so.
Grüße/Regards
Hallo Rob,
ich habe mir gerade die neue Version 1.0.6 angeschaut.
Gefällt mir sehr gut.
Ich habe noch einen Verbesserungsvorschlag.
Bei mir auf dem Tablet ist der angezeigte Text, z.B. bei der History (aber auch auf Haupt-Page) sehr eng am Displayrand. Das empfinde ich als unangenehm beim lesen.
Liegt evtl. auch an der HW meines TAB.
Ich denke wenn du grundsätzlich ein paar Pixel Rand einbauen würdest wären die Texte leichter lesbar.
PS: Beim Download des OSTC4er Files wird mir immer ein CS-Fehler angezeigt.
Olaf
Olaf
Hi Plaf,
der Fehler bei den OSTC4 downloads ist bekannt.
Stört aber ncit, da der OSTC4 firmware Update noch nicht implementiert ist.
Wird wohl auch noch etwas dauern.
Ich kann mal schauen ob ich den Rand von Pixel auf % umstellen kann, das sollte für Tablets eine Verbesserung bringen.
Grüße
Grüße
Hallo Rob,
ist irgendwann auch eine iOS Version geplant?
