Update 30.07.2020 (V 3.12)
The new hwOS tech (for OSTC3, plus, cR, OSTC 2 and OSTC sport (mod. 19)) firmware 3.12 is now available for download:
This update is (still) strongly recommended for all users of the 3.03 or 3.05: OSTC with hardware versions 13-xx-xx and 58-xx-xx could hang up with single-language versions of 3.03 or 3.05
[3.12]
BUGFIX: Deco paramters (Saturation/Desaturation) were shown false in the logbook and surface screen (Non-GF deco mode only)
BUGFIX/CHANGE: Saturation/Desaturation parameters are moved into thier own Sub-menu (Non-GF deco mode only)
BUGFIX: Screen startup behaviour (OLED Limited Edition only)
[3.11]
BUGFIX: configuring deco gases via the mobile Apps was not possible
CHANGE: French language fixes
[3.10]
- Hardened all USB/Bluetooth communication against data losses and timeouts
- A new Firmware Recovery Feature has been added: the currently active firmware can be backed-up and restored later on while other firmwares have been loaded thereafter. The feature is accessible via Settings -> System Settings -> Reset Menu -> Reboot and becomes available with the first firmware load after the V3.09 beta 4 (or later) is already on the unit.
- New option to acknowledge the most recent warning in dive mode (Left press -> Ackn?)
- Removed option 'ascent speed', ascent calculation is done with a fixed speed of 10 meters/minute now (equals the ascent speed limit by Bühlmann).
- Improved calculation accuracy of the initial ascent. Remark: this will have a slight impact on the resulting deco schedule compared to firmware 3.08.
- The deco calculator now figures in the salinity setting.
- Aligned logbook and last dive summery of avg and max depth regarding rounding and incorporation of salinity setting.
- Done some fine-tuning of depth outputs when using imperial units (feet).
- In dive mode, sometimes the temperature was not shown any more after a gas change - fixed now.
- The menu system around setting up the dive mode & settings has been decluttered. All settings are now sorted into the groups dive setup, deco setup, SAC (gas needs) setup, ppO2 setup and stops & depths setup.
- There is a new option "Swap on empty" in Dive Setup -> SAC Setup. It is only effective if "CalcGas(B/O)" is switched on, too. If both options are switched on, the deco calculation will switch to another tank (i.e. gas) once the tank of the current gas is calculated to be used up. This function can be used to automatically calculate a contingency in case of running out of a deco gas, as the deco calculation will then continue to calculate a deco making use of the spares from the another gases carried. Another application is with two or more tanks holding the same gas (i.e. independent double configuration, side-mount), as the calculations will then take the cumulative amount of gas carried into account before raising a gas needs attention or alarm.
- Fixed the urge of the better gas hint to always favor one specific gas out of a set of two or more gases that have the same change depth.
- For dives done on firmware >= 3.08 the logbook will have one more pageshowing the tissue pressures and supersaturation levels as of at the
end of dive (i.e. when surfacing).
- As long as a gas or diluent is currently selected as breathed, it can not be set into the lost state any more.
- When changing the battery or doing a cold start, the current CNS value does not get lost any more.
- During loading of a new firmware the clock will not loose time any more (on old firmware it became late by about 15 sec on each firmware update).
- When run from a 3.6 V battery (either replaceable or built-in), the surface mode timeout is now extended to 4 minutes before going to sleep
mode. If the OSTC is run from 1.5 V disposables, the timeout remains at the previous 90 seconds to save on battery runtime.
- Internal improvement: the code for the internal storage system and for the communication system (firmware uploading, dive data downloading)
has been re-factored to secure maintainability for the next years to come.
- Internal improvement: the scheduler for the dive mode calculation plans (fTTS, bailout) has been completely rewritten for better maintainability.
[3.08]
BUGFIX: "Sticky" button behaviour on some hardware versions (Only OSTC 2 (2017), TR and OSTC plus)
The version has many new features and changes, but the basic settings have not changed much since 3.01 and OSTC experienced users will be fine with it at once. By popular request some settings have been extended and added. Thus the gas change is suggested again independently of an actual deco stop at the change depth and also the maximum ppO2 can be set beyond 1.6bar. As always, this applies here: Changes to the basic settings via accepted limits (GF>100, ppO2>1.6) are the responsibility of the user. In order to correctly forecast the TTS even when using more than one or two decogases (OC), a little more care must now be taken in the gas setup for such dives. For example, the MOD/change depth must also be set for the start gas (First) so that the OSTC can propose and predict all gases in the correct order. However, this still applies unchanged: Each gas from the gas list can be selected at any time in the dive. Unsuitable gases are already marked red in the gas list and a warning/recommendation is issued when selecting. The control remains however to 100% with the user.
Die neue hwOS tech Firmware 3.12 (für OSTC3, plus, cR, OSTC 2 und OSTC sport (mod. 19)) ist jetzt zum kostenlosen Download verfügbar:
Für alle Nutzer der 3.03 und 3.05 ist dieses Update (immer noch) dringend empfohlen: OSTC mit hardware versionen 13-xx-xx und 58-xx-xx konnten im Oberflächenmodus einfrieren (Nur bei den Ein-Sprachen Versionen der 3.03 und 3.05
[3.12]
BUGFIX: Die Angaben für die Sättigungs/Entsättigungs-Mulitiplikatoren im Logbuch waren fehlerhaft (Nur im Nicht-GF deko modus)
BUGFIX/CHANGE: Die Sättigungs/Entsättigungs-Mulitiplikatoren haben nun ein eigenes Untermenü
BUGFIX: Startverhalten des Bildschirms (Nur OLED Limited Edition)
[3.11]
CHANGE: Updates bei der Französischen Sprachversion
[3.10]
BUGFIX: Verbesserte Berechnungsgenauigkeit des Erstaufstiegs. Bemerkung: dies wird einen leichten Einfluss auf den resultierenden Dekoplan haben, verglichen mit der 3.08
ÄNDERUNG: Das Menüsystem zum Einrichten des Tauchmodus und der Einstellungen wurde aufgeräumt. Alle Einstellungen sind jetzt in die Gruppen TG-Einstellungen, Dekompression, SAC (Gasbedarf)-Einstellung, O2 Partialdruck und Stopps und Tiefen einsortiert.
NEU: Für TG mit Firmware >= 3.08 wird im Logbuch noch eine weitere Detailseite mit Sättigunsdaten angezeigt
NEU: Eine neue Firmware-Wiederherstellungsfunktion wurde hinzugefügt: die derzeit aktive Firmware kann gesichert und später wiederhergestellt werden, während andere Firmwares geladen wurden. Die Funktion ist zugänglich über Konfiguration -> System -> Reset Menü -> Neustart/Backup und wird mit dem ersten Laden einer Firmware verfügbar nach der 3.10 (oder später).
ÄNDERUNG: Bei Betrieb mit einer 3,6-V-Batterie (entweder austauschbar oder eingebaut) wird der Timeout auf 4 Minuten vor dem Einschlafen verlängert. Bei 1,5V Batterien bleibt es bei 90 um die Batterie zu schonen
ÄNDERUNG: Interne Verbesserung: der Code für das interne Speichersystem und für das Kommunikationssystem (Hochladen der Firmware, herunterladen der Tauchdaten) wurde umstrukturiert, um die Wartbarkeit für die nächsten Jahre zu sichern.
ÄNDERUNG:Interne Verbesserung: der Scheduler für die Tauchmodus-Berechnungspläne (fTTS, bailout) wurde zur besseren Wartbarkeit komplett neu geschrieben.
[3.08]
Die Version hat zahlreiche neue Funktionen und Änderungen, in den Grundeinstellungen hat sich jedoch nichts Grundlegendes zur 3.01 geändert und mit dem OSTC erfahrene Benutzer werden gleich damit zurecht kommen. Auf vielfachen Wunsch hin wurden einige Einstellmöglichkeiten erweitert und hinzugefügt. So wird der Gaswechsel wieder unabhängig von einem tatsächlichen Dekostopp auf der Wechseltiefe vorgeschlagen und auch der maximale ppO2 lässt sich über 1,6bar hinaus einstellen. Wie immer gilt hier: Veränderungen an den Grundeinstellungen über anerkannte Limits (GF>100, ppO2>1,6) liegen in der Verantwortung des Benutzers. Um die TTS auch bei Verwendung von mehr als einem oder zwei Dekogasen (OC) korrekt zu prognostizieren muss bei derartigen TG jetzt etwas mehr Sorgfalt im Gas Setup angewendet werden. So muss z.B. auch für das Start-Gas (First) die MOD/Wechseltiefe eingestellt werden damit der OSTC alle Gase in der richtigen Reihenfolge vorschlagen und vorausberechnen kann. Hier gilt aber weiterhin unverändert: Jedes Gas aus der Gasliste kann beim TG zu jedem Zeitpunkt gewählt werden. Unpassende Gase sind dabei schon in der Gasliste rot markiert und bei auswählen wird eine Warnung/Empfehlung ausgegeben. Die Kontrolle bleibt aber zu 100% beim Benutzer.
How to install: viewtopic.php?f=6&t=14509
hwOS tech: Version 3.12 released
Christophe
Re: hwOS tech: Version 3.11 released
Bonjour,
Merci pour les corrections apportées ;)
Bonnes plongées !
Bonnes plongées !
Is the problem with the ambient light sensor fixed in version 3.11?
I have a OSTC+
With this new release, I can't set the S/D in ecotype ZH-L16* (without GF)
For exemple, I choose 120% for Saturation, and 80% for desaturation in the menu Deco Setup. But no change on the display, the previous setting 110/90 stays (even if I take off the battery and fit it again)
I did not understand something or it is a bug ?
Thanks for your help
GD
I have a OSTC+
GD
indeed, it is a bug. The menu gives access to the S/D of GF mode only while those for none-GF stay on their default. A fix is already programmed and will role out in due time.
Ok, clear.
In the meantime, I will use only GF.
Better anyway, or simply use GF-model with GFs set to 100/100, that has the same effect as selecting the none-GF model...
Re: hwOS tech: Version 3.12 released
This is now available for all hwOS tech users. Here, besides this issue not beeing able to change the S/D parameters (in NON-GF mode only), this update is more a cosmetic update and comes with no new features or major changes to the 3.11.Ralph wrote: 12 Jul 2020, 06:26 indeed, it is a bug. The menu gives access to the S/D of GF mode only while those for none-GF stay on their default. A fix is already programmed and will role out in due time.
Bitte hier weiterlesen/schreiben: viewtopic.php?f=6&t=22156
