I read from the manual that it takes up to six hours to download completely. For me it's way more than that because the computer warms up and stops charging untill it cools down. Does everyone else's computers warm up? And how much?
At room temperature 23-24C it takes 12h to charge from ~80% to 100%.
Warming while charging
Re: Warming while charging
Yes it does heat up and when it gets too warm it stops charging.
I don't discharge it more than 70% and I let it charge overnight. I also make sure its in a well ventilated area to charge.
I actually put the charging part and computer once in water to test and it charged quick. But I can't be bothered now. Besides electricity and water don't mix.
Walde
It would also help if the charging percentage was displayed during charging.
tdewilt2
I cool the computer while charging in water with a small cooling block. cooling with water in a room temperature room works wel.
TomtheRom
This sounds interesting for me :-)
[quote=tdewilt2 post_id=24124 time=1677618033 user_id=3015]
I cool the computer while charging in water with a small cooling block. cooling with water in a room temperature room works wel.[/quote]
Do you have any pictures an reccommendations regarding the cooling block?
I really struggle to load my OSTC4 - sometimes is looks all good and reports an full load within 1-4 hours, but over night its still not full.
So I really appreciate any support in this aerea.
Thanks in advance and best regards
Thom
Thom
mikeller
Thanks guys for this input - cooling the dive computer is indeed working great to get it to charge faster!
I have made a new version of a charging cradle design that I did a while ago. This new version allows mounting of a cheap 60mm fan next to the OSTC4, and it substantially reduces charging time. The fan is only pushed onto the cradle, so it can be removed easily, making this a very portable solution.
Next version will be water cooled
mikeller
Walde
Have done few trips to very warm places like Indonesia and I have to say that the warming is really annoying. If you don't have good AC it's impossible to charge OSTC4. When doing multiple dives per day you can barely charge the computer enough during night. I also have OSTC2 and there's no problems with that.
I hope that OSTC5 gonna be like OSTC2
