OSTC MK1 False Max Depth
BlupBlup
Post by BlupBlup »
I've a little problem with my OSTC on Saterday.
I dive up to 80m. After U-turn, I discover the max depth is 99.9m. Stop info and TTS seems to stay coherent with the planning. In the log book the max depth of this dive is 139.44m :(.
When downloding in JDIvelog the depth is "normal" (80.07m).
I'd also an other problem on Sunday. No problem during the dive but after the dive it was impossible to turn it on. I've to connect it to the PC and push the reset.
BRs
Ghislain
BlupBlup
Re: OSTC MK1 False Max Depth
Post by BlupBlup »
Software level is 1.50
Mode is: L16-GF CC
Water temperature was between 4 and 7°c and battery was last charged 20 days ago (maybe an explanation for the second problem) but the battery info said lowest on 05/01/10
Ghislain
Dear Ghislain,
This may be a bad solder contact at the pressure sensor - a problem we had sometimes before with the OSTC1. If it's this issue we should check this at our place.
