A friend of mine has an older OSTC 3+ (#4806, 2016, Bluetooth), is this sleeve compatible ? What are the mechanical / dimentionnal differences between OSTC 3+ 2016 and 2019 OSTC Sport 2019 ?
Best regards.
Hello
i have an ostc2 computer i would like to make the cover, i also have the 3d printer, i would like to print the cover, have any of you made the design of the cover, thanks
delyan.dilkov wrote: Sunday 29. April 2018, 07:34
Hi there.
I also checked @ innodive and you cannot get it separately.
You can make an outer shell with a 3D printer as I did for my OSTC Plus. If you are interested I could try and send you some photos of it.
Regards.
It is possible to get the .STL File of the OTSC Plus Cover?
Did you have printed it "in/with" TPU?
heinrichsweikamp wrote: Friday 11. May 2018, 13:06
> can you also share the files for the OSTC 2 from
> 2015?
Here you go.
Hallo zusammen!
Ich bin auch gerade dabei, mir eine Hülle für meinen OSTC 2 (ab 2017) zu konstruieren.
Den genau zu vermessen, ist ja nicht das Problem, aber mit einer STL oder STEP vom OSTC 2 könnte ich mir Sicherheit eine perfekt sitzende Hülle drucken.
Hat schon jemand eine der Dateien?
Wäre es möglich, diese zu teilen?
