Hi
My screen is extremely scratched.
Does any of you have tried Polywatch that is used to restore minreal glass from vintage watches on their OSTC ?
Ploywatch? Remove Scratches
Re: Ploywatch? Remove Scratches
Have you checked that there is no screen protector attached to the glas? Sometimes it is hard to see, look at the outer edges of the screen for a jump in "screen hight".
Motardplongeur
Before trying "Polywatch" (which normally do not work so much w/ mineral glass ; only on plastic), you can test w/ toothpaste (the lowest price is the best one !) or what we call in France "Miror" (for silver or copper) ; or "pierre d'argent" (this is a paste).
Something to know : if you feel clearly scratches w/ your nail, no one product will solve your issue ; only small ones can be removed.
OSTC #12002 & #11150
Satyre
Merci beaucoup je vais essayer d,abord avec le dentifrice puis le MirorMotardplongeur wrote: 02 Jan 2025, 18:13 Before trying "Polywatch" (which normally do not work so much w/ mineral glass ; only on plastic), you can test w/ toothpaste (the lowest price is the best one !) or what we call in France "Miror" (for silver or copper) ; or "pierre d'argent" (this is a paste).
Satyre
Good point on one of the OSTC there is such screen protecteor on the oldest one unfortunately noRalph wrote: 02 Jan 2025, 14:52 Have you checked that there is no screen protector attached to the glas? Sometimes it is hard to see, look at the outer edges of the screen for a jump in "screen hight".
I doubt that you can remove the scratches properly from the glass. I think you should leave it as it is rather than trying to polish it with questionable means. A protective film may even help to fill these scratches. This will make them barely visible (Same refractive index then the glass).
Satyre
Well noted.
Thanks Matthias
Thanks Matthias
Motardplongeur
Tiens nous au courant !Satyre wrote: 03 Jan 2025, 11:13 Merci beaucoup je vais essayer d,abord avec le dentifrice puis le Miror
