OSTC3 problem with data and Bluetooth
Marcomet
Hello. I have OSTC3 SN3090 with software 3.13 Rel.
Unfortunately there is a problem with the date.. I can't change the year above 2024.
I downloaded the latest firmware. but I can't turn on Bluetooth.
Is it possible that my computer does not have this module.?
Kind regards
Marc
Kind regards
Marc
Re: OSTC3 problem with data and Bluetooth
Hi Marc,
In 2015 I had an OSTC 3 S/N 3999, it has a USB connection but no Bluetooth. Yours being S/N 3090, I guess it is the same model. So try to update the firmware through UCB.
Marcomet
HI
thanks for the answer.
But here again the problem..
I only found an optical input.
Is that what you wrote about.??
I've never used it. I bought it used - and I don't even have such a cable..
https://mail.google.com/mail/u/0/#inbox ... rojector=1
Marcomet
sometimes the closer you have something to your eyes.. the less you see!
of course I found it..and I looked at it so many times...
I never opened it.. because there was no need
one more time..thanks for your reply
You got it !
Marcomet
please help..
what am I doing wrong?? can't connect..i've been trying for an hour.
Did you do it??
Did you do it??
jb2cool
How sure are you that this particular USB cable can send data? I’ve seen some that’ll charge things but don’t send data.
Marcomet : are you sure your computer is connected to COM5 and not to another COM port ? Have a look to the Windows peripheral panel.
jb2cool : yes, this USB port is the only way to update the firmware and download dive profiles since there is no Bluetooth on this unit.
Regards.
Regards.
This is one of the cases where we have the exact same questions via email in parallel. So we send an email with some support here already.
@Marcomet
Have you tried anothercable!?
