Hi All,
Is the OSTC + available as 4 Pin version?
br
Chrischd
OSTC + 4 Pin?
Re: OSTC + 4 Pin?
What kind of connector is " 4 Pin"?
Re: OSTC + 4 Pin?
like the "Shearwater Petrel 3 with AK 4-pin monitor cable connection" for the KISS classic for example
br
Christian
br
Christian
Re: OSTC + 4 Pin?
It would be more helpful if you told us what you want to achieve!
With the OSTC+ you have the option of Fischer and s8 connector.
The ak 4pin would be hardwired on the Shearwater, I would have thought.
With the Kiss Classic you have Molex connectors to the cells I assume.
Therefore your options for the OSTC+ are Fischer or S8. On my Sidewinder I use an S8 connector to the OSTC(5), which gives a waterproof seal to the OSTC (as opposed to the Fischer connector). So no need for ak 4pin.
But as I said, depends what you are trying to do...
Re: OSTC + 4 Pin?
I wonder wether I can Connect my Kiss with the AK 4 Pin to a OSTC + to monitor the 3 O2 cells.
br
Chris
br
Chris
Re: OSTC + 4 Pin?
The OSTC+ has either Fischer or an S8 connector.
You can...
...but.
Might help if you PM me on FB/Messenger: Dave Cave.
We can discuss the details.
You can...
...but.
