Hallo, obwohl das Interface korrekt installiert ist, der Tauchcomputer an ist,kann ich den OSTC nicht auslesen. Fehlermeldung - Searching for PIC ...Not found, ERROR! Mei Betriebssystem ist Vista, die Firmware auf OSTC ist 1.10.
Gru? Mark
Auslesen OSTC
Auslesen OSTC
Hallo, Problem ist gel?st. Interface ist defekt. Mit einem anderen geliehenen Interface funktioniert es super.
Gru? Mark
Gru? Mark
corona_citron
Re: Auslesen OSTC
I've got the same problem but no one seems to have the answer...
Re: Auslesen OSTC
In this case the interface was defective.
corona_citron
Re: Auslesen OSTC
I must say I have tried on another PC. It doesn't work.
Of course I have to mention that the driver's install procedure is not really well described...
If I push on the reset, it works but the tiny shows always 'ERROR'
And the connection remains unavailable
Do I have to send back the interface ?
May I have an answer from HeinrichsWeikamp, please ?
Re: Auslesen OSTC
We're currently not in the office, so answers are much slower then usual, sorry.
First, is the the "TX" LED blinking when pushing the "Write Button"? It should blink two times/second for 10 seconds. If not, the port is set wrong or the driver is not properly installed.
Then, during the ten seconds, press the reset button and the update should start.
Recently, we had one case where the interface was defective. This may be the problem here, too. Can you simulate or download dives with Divinglog?
corona_citron
Re: A few questions
all is fine now with my connection problems. It was only a bad solder on the connector of the interface. 2 pins were together.
Kind Regards
Michel
Kind Regards
Michel
