Olivier Wrote:
> Jean-Do, no worries... My unit is still
> calculating (2 days after) deco time as I have no
> magnet at home (and pretty busy right now to buy
Hi Olivier,
You can also interrupt this by removing the battery. Or wait until the battery is empty, which should happen in the next 24hours.
This issue was likely related to a non-set gas consumption custom function (CF56 and/or CF57)...
New 1.84 beta available for the Mk.2
Re: New 1.84 beta available for the Mk.2
Hi Olivier,
Just stack some fridge magnets. That's what I did and it worked a treat.
D
D
OSTC MK2 1394
Olivier Wrote:
Jean-Do, no worries... My unit is still calculating (2 days after) deco time as I have no magnet at home (and pretty busy right now to buy one). But as far as I remember, I launched a simulation with following parameters:
- 1.84 english
- ZHl16
- G1 air and G2 Nx 82@9m, others inactive
- GF11 115%, others default
- tried to simulate 21mn @ 75m, or something like that. Minutes went down quickly as expected and is now stuck with 1min left
Nope... the beast escaped. Most probably because of various resets done on my units while testing.
Once you get back access to it, can you try Reset CF, Gas & Deco ?
Thanks!
- 1.84 english
- ZHl16
Thanks!
Hi JeanDo,
I did reset the CF's a number of times with the same outcome... go figure
D
D
OSTC MK2 1394
