Hello everyone
Well, I have a little problem with setting CF43 (DepthWarm), I explain, the default is 13000 and the setting is either 1 or 10. When I want to position the adjustment in 5000 is very long and tedious to descend from 13,000 to 5000. Will not be there not possible to add in an update to an additional adjustment to 100, it will save time.
Moreover I tried to change the default with JDiveLog, replacing 13,000 by 6000, and is the default value is taken into account by JDiveLog but not on the MK2. When I reconnected, the default is 6000, but still not on the MK2??
Thank you for your help.
Xavier ...
CF43
Re: CF43
a +1, +10 and +100 option is on my ToDo-List for quite a while now...
Re: CF43
Hello Matthias
Another track for the CF43 is very slow to change. Rather than as a unit of mbar why not put in bar. The setting of 1 / 10 will always be good and there will not need to 1/10/100? The adjustment mbar is not really very important.
Cordially
Xavier ...
Cordially
Xavier ...
