New firmware 2.0 stable is now available
Paolo Di Mario
Re: New firmware 2.0 stable is now available
Hi, I made several attemps to connect my N2 to my computer and it comes a message where it says that is an unknown device and cannot comunicate. I have windows 7 and it's supposed to have some driver that should work. Do you have a driver tat can fix the problem?
Thank you
Thank you
Paolo Di Mario
I finally could connect the N2 to my computer with the bootloader, not with diving log 5.
After loading the firmware 2.0 active gas are blu like the inactive. The only white one is the first gas. I downloaded it twice and reset the N2. Still the same problem. Can it be fixed? It's quite helpful to read at once which one is active like it was in the 1.9.
Thanx for your answer.
that`s ok. Please look in the manual S.22 (More / Active Gas - Yes)
OSTC MK2 407
Paolo Di Mario
Thank you Longli, but I had already set three gas active (more / active gas -yes) and two inactive. The only one colored in white is th first gas. I must have tryied 20 times.I think is the new firmware that doesn't do it.
Thanx for your attention anyway,
Paolo
Paolo
@ Paolo: Knl described this problem a few posts above but didn't write again that he still has the problem. Within my unit it works... maybe you should make a reset of the gas menue and try again?
Paolo Di Mario
Thanks again, I did indeed reset just about everything: the device itself, the gas and deco menu, decodata and logbook. No way, nothing changes. I getting sure is a bug. My device is N2, may be it works on some other model.
If you know anything more, please, let me know. This thing is rather annoing.
All the best,
Paolo
All the best,
Paolo
Fabrizio Vizzani
Hi I'm new to the forum and i've just started to use my new 2N ,OSTC 2798.
Paolo,
I've installed the new firmware and found no problems on active/inactive gas, but it seems necessary to set the value of "Change" parameter in the gas menu to a value greater than zero,or the gas will be inactive also if it is flagged active.
Looking the dive graph on the logbook I find two curves (profile and temperature) an one shape (in pale green) contained above the curves.
Does someone know which is the meaning of the shape?
Thanks.
Fabrizio
Paolo,
Thanks.
Fabrizio
you switch on EAN see the next page in the logbook OSTC.
OSTC MK2 407
Paolo Di Mario
Thank you Fabrizio, you are right! The defoult value sounds just like a simple calculation on PO basisis. The depth change MUST BE SET by the user to make the gas active. Not a bad idea. would have been nice to know it! Congratulations, you cleared the mistery.
All the best,
Paolo
All the best,
Paolo
The pale green shape is the deco ceiling depth.
Ed
Ed
Fabrizio Vizzani
Thanks Ed and Longli, reviewing logbook graphs at the light of your answers it seems that the "pale green shape" represents the phase of the dive out of security curve, and its area gives a measure of deco time during the dive.
Almost. The length of each green strip represents the depth at which you would need to deco stop, at that point in the dive. So if after 30 minutes into the dive there is a strip that extends down to 9m, you would need to do a 9m deco stop.
Ed
Ed
Fabrizio Vizzani
Thanks Ed; now the meaning of "pale green shape" is completely clear
Hallo Zusammen
Update hat funktioniert!
Leider kann ich die uhr nicht mehr
stellen, hat jemand eine Idee wie
ich das problem lösen kann?
Danke viel mal
Gruss
Patrick
Danke viel mal
Gruss
Patrick
Patrick,
Wo kannst du die uhr nicht stellen?
HJ
HJ
Hallo Hansjoerg
Früher konnte ich es am ostc nun geht
es per sync. brauchte einen moment bis
ich es gefunden hatte!
gruss
patrick
gruss
patrick
Salut Patick,
Am 2N hat sich nichts geändert.
- Mit dem linken Sensor MENU auswählen > mit dem rechten Sensor bestätigen
- Mit dem linken Sensor zum Menüpunkt MORE navigieren > mit dem rechten Sensor bestätigen
- Erster Menüpunkt im Menu2 ist SET TIME > mit dem rechten Sensor bestätigen
- Jetzt kannst du die Zeit setzen
Hallo Patrick.
Bist du bei der Zeiteinstellung weiter gekommen?
Hallo Hansjoerg
Konnte die Zeit über den PC Synchronisieren.
Danke viel mal für deine Hilfe!
Gruss aus der Schweiz
Patrick
Patrick
Patrick,
No problemo...
Gut Luft!
No problemo...
Gut Luft!
Paolo Di Mario
Everything is ok, yet in sunlight the dark blu of the gas list is invisible.
CJ
can´t download the new firmware via bootloader
=> Looking for http://localhost/default.hex
downloaded the file from the homepage and still can´t get it updated
=> Connected to \\.\COM1 at 115200
HEX: 18 days old, INHX32,18Fcode+cfg, total=81498 bytes.
ERROR!
Not found!
best regards
cj
ERROR!
Not found!
best regards
cj
CJ
... found the problem
=> the piccodes.ini file was missing
good night everybody
....need a little help from my friends......
Yesterday, i run the update to V2.00 via bootloaderV2 - so far, so good. Everything was fine, but i lost german language in the system.
V2.00 stable only in english or did i make a mistake
how to install V2.00 in german
best regards
Carlo
best regards
Carlo
after unzipping the V2.0 zip-file you have 5 different MK2-V200-stable files in your folder.
Plain is english, deutsch is german, espanol ist spanish, francais is french and russian is russian.
Choose the one you like for your MK2.
If you choose the plain file you'll end up with english.
For german choose the file "deutsch".
