High altitude / Bergseemodus?
Post by scubatinoo »
How does the OSTC react in higher altitudes? Are there any ranges like 0-700m, 700-1500m and 1500 and higher or will the calculating be done by actual pressure? It's just because i red in the manual, that the sensor (Barometer) "is not very exact"...
Wie funktioniert der OSTC in grösserer Höhe (Bergsee)? Sind auch Bereiche definiert wie 0-700m, 700-1500m und 1500 und höher oder wird die Sättigungs/Deko-Berechnung aufgrund des aktuell gemessenen Luftdrucks gemacht? Habe nur grad im Manual gelesen, dass der verbaute Sensor (Barometer) nicht sehr exakt sein soll...
Bardass
Re: High altitude / Bergseemodus?
Post by Bardass »
Where do you read that in the manual ?
OSTC use ambient pressure for calculations, Cf Bühlmann decompression algorithm
Bardass
German Manual, Page 32 --> "Altimeter"
If i'm standing at a lake 2000 meters above sealevel, how can i check that my OSTC uses "the right altitude"?
Ambient pressure in 2000m can change by weatherconditions...
Bardass
Post by Bardass »
you're wrong
OSTC calculate an estimate altitude (in meters or feets) depending on weather conditions : altitude varies because the pressure varies.
the warning is related to the exact calculation of the altitude, not pressure.
If you want a correct altitude, don't use OSTC or recalibrated it with a moutain map.
OSTC don't need to get the correct altitude to calculate decompression. Altitude is just an information.
even if the pressure was slightly wrong, it would not matter : decompression is calculated from PRESSURE GRADIENTS between surface and depths
Bardass
So i missunderstood the altimeter function... but if the altimeter is not used for anything, why is it interesting? there are less expensive digital altimeters available... :)
Bardass
Post by Bardass »
the calculation and display of the altitude were asked by some divers only as an information
they were provided by HW in version 1.8, if i remember
http://www.heinrichsweikamp.com/read.ph ... 7#msg-3987
see JeanDo
Bardass
ok, i see the dilemma ;)
JeanDo
Post by JeanDo »
By the way, I did the Altimeter, and are at the origin of the "not very precise" comment. It means +/- 40m (once you calibrated it from the meteo). This is the noise of the pressure sensor.
Obviously, it have no measurable incidence on the decompression results. :)
