Beta 1.23 available
Beta 1.23 available
The new 1.23 has some new features:
- Added standalone Simulator (Menu->More->Simulator)
- O2 Sensor reading is updated in Divemode menu automatically
- Menulook improved
- All three Sensors readings can be displayed in Divemode menu ("O2 Mon.")
- added bigger font for Depth display
Feedback and critics are very welcome!
Die neue 1.23 Beta hat einige neue Funktionen:
- Ein PC-unabh?ngiger Simulator wurde hinzugef?gt (Menu->More->Simulator)
- Alle drei Sensorwerte k?nnen im Tauchmodus angezeigt werden ("O2 Mon.")
- Die Men?s wurden optisch aufgewertet
- Die Tiefe wird deutlich gr?sser und klarer dargestellt (Neue Schriftart)
R?ckmeldungen und Kritik sind wie immer willkommen!
Gruss,
Matthias Heinrichs
- Menulook improved
Gruss,
Matthias Heinrichs
servan
Re: Beta 1.23 available
* the simulator is great.
* the battery led is not blinking
Servan
Servan
Hello, thanks a lot for the standalone simulator, Reiner
servan
Yesterday I dive with the 1.23. No Problem.
Deco mode : ZHL16 - GF - CC
Default gas : G3 = 14/40
This morning I want to show the simulator to a friend...
So I changed the deco mode to ZHL16 - GF - OC
First gas G2 = 20/30
1. The decomode was still : ZHL16 - GF - CC. I've got in the Setpoint menu. So I finished the demonstration in CCR mode...
2. Do not fly time is superior than the desat time. Now --> NoFly : 4:29 -- Desat : 1:12
Servan
Servan
How is CF 13 configured?
servan
CF13 = 60
And now :
* NoFly = 4:01
* Desat : 1:20 (It increases)
And now :
* NoFly = 4:01
Jostein
Just returned from the 1st dive with 1.23. Desatt-Time and NoFly time are correct for me
New "depth" font is great.
Simulator should restore current tissues after simualting. Ist das moeglich?
J. Stein
J. Stein
Olivier
Hello Matthias and everybody,
A little bug: dives in the logbook are not shown in a right order (i.e. the last dive frontmost), but in a completly anarchic order: in my case, 9th month first, then 10th, then 12th, then 11th...
Thank for all and merry Christmas.
Olivier
Olivier
servan
After the two simulation, my logbook is partially erased. The 2 first dives are deleted. And the 2 simulated dives are stored.
Servan
Servan
nicolas schreyer
a little add:
it is also not possible to download my two last dives...
back to 1.22...
back to 1.22...
Same here: Do you see any error message or are the two dives just not in your logbook at all? Does the internal logbook show the dives? I will publish a 1.24 with some improvements of the logbook management on Monday. Possible that this version will see the dives.
nicolas schreyer
the logbook is avaible; but:
1? the 23rd Dec. dive's is logged on #25...and when I open it, it displays the 1st March date...
2? the today's dive is not downloadable (Divlog)...
and right now as I tried to control the dive #2 it switched off and don't look to want waking itself up...
(I was already back on 1.22)
Ok, definitely some problems with the profile memory writing in the 1.23... Will take care of that tomorrow.
nicolas schreyer
and what about the reanimation ?
do I try the reset button on interface ?
Yes, seems that the probably defective profile hung-up the logbook (Second bug I will look after).
nicolas schreyer
reset: OK!
it runs again...
it runs again...
Hello Nicolas,
If you want to, you can try the attached version. I will upload this version to the firmware page tomorrow from the office. Has several bugfixes in the logbook menu.
nicolas schreyer
Matthias, do you think the logged dives are able to be saved or they are to delete ?
Hello Nicolas,
I think these dives can be saved, at least from us with a HEX editor. Does 1.24 show the dives?
