OSTC 2798.
Hi, planning a dive with 3 gas (all active TX 21/30 ,Ean 50 ,Ean 98, but it is the same using other gas) , my ostc calculate deco plan using only the first gas.
Did someone observed the same behavior ?
Fabrizio
Planner problem
Re: Planner problem
Maybe you did not define a changedepth for each decogas? You have to set a depth deeper than 0m to really activate the gas and make it possible that it is included in the planning.
Fabrizio Vizzani
Re: Planner problem
Thanks, but all gas are active,and the simulator work correctly signalling the
switch at planned depth, while the planner calculate the same dive only with the first gas.
Fabrizio
Fabrizio
Fabrizio Vizzani
Re: Planner problem
Hi, problem solved; the exact cause is not clear.
I'did a reset of all CF, and then i set all CF to their previous value.
Now the planner and other functions work well.
