OSTC_eeprom.h
Mr_C
OSTC_eeprom.h
Post by Mr_C »
I have searched through the forum hoping to find my answer. Hopefully, this will make sense.
I am attempting to compile the bühlmann/GF code found in the p2_deco.c file and am doing this on a Mac (unix). Anyhow, I am getting a compiler error saying the OSTC_eeprom.h is not found. I have looked through all of the source and do not see this file.
Is it part of another source tree?
Thanks for any pointers.
Eric
Iglooz
Re: OSTC_eeprom.h
Post by Iglooz »
As far as I have understood, this file is only requested in native context for eeprom simulation.
For my need, I'm using this stub ...
OSTC 2N #2755
Mr_C
Re: OSTC_eeprom.h
Post by Mr_C »
thanks. Since I am trying to use the deco code exclusive of the eeprom, I might have to go and modified the code. But will see if your header file gets me over the hump.
Eric
Iglooz
Re: OSTC_eeprom.h
Post by Iglooz »
As far as I can see, this stub is just used to simulate the accesses to CF54 ... CF58.
You can easily stub the code but you will loose the benefit of reusing a maintained p2_deco.c file which is also embedded like that in the OSTC.
OSTC 2N #2755
