New 1.75 beta for the OSTC Mk.2
Re: New 1.75 beta for the OSTC Mk.2
heinrichsweikamp Wrote:
> > 1) Decoplan (in simulator) now shows decostops in
> > ascending order
> Maybe in the 1.81. We have the problem here that
> if we change it, the other 50% of our users
> complain...
Therefore I suggested this as customizable with CF.
> > Maybe change "CF29" to the "Last"?
> > "Last:3m" - it is probably clear?
> What do others think? Any suggestion for a
> 4-letter abbreviation for CF11 and CFC12?
"GF-H:"
"GF-L:"
"Last:"
> > 4) Simulator: Blinking gas to change it to better
> > (nice function!) starts only below the optimal
> > depth to change - for 100% O2 at 5 meter, not at 6
> > meters when I should change the gas.
> We can change this, but the gas change reminder
> was intend to be some kind of a warning in case
> you missed the stop. We strongly recommend
> wetnotes for multi-gas dives with a list of gas
> changes.
Yes, yes! Comp is (for me) only a backup device in most my divings. But I think that this blinking should be at depth to change, not below.
Jacek
> > ascending order
> complain...
"GF-H:"
"GF-L:"
"Last:"
> changes.
Jacek
Jacek
OSTC MK2 1175
OSTC MK2 1175
Hello Mathias,
great news ! Thanks.
I vote for Jacek:
"GF-H:"
"GF-L:"
"Last:"
Cheers, Heiko
I vote for Jacek:
"GF-H:"
"GF-L:"
"Last:"
Cheers, Heiko
CF11 and CF12 are the desaturation multipliers used in normal Bühlmann (Non-GF). We can only put the "Last:" in the GF modes or just leave "CF11" and "CF12" in normal Bühlmann mode.
> Menu -> ResetAvr
but I don't want to reset average depth. Just stopwatch, to time my stops better.
> Leading tissue change, happens with little
> decompression load from time to time.
ok, will keep an eye on it
+1 for Jacek's proposal on GF-H,GF-L, Last, and for customizable sorting order of the decostops.
> Menu -> ResetAvr
Kind regards,
Gorcio, OSTC MK2 828
BALDEAGLE
> Hi Dave,
> Yes, there will be 1.8 for the OSTC1 but a lot of
> the new features only work with the display space
> of the Mk.2, unfortunately.
> regards,
> Matthias
Thanks for the prompt response Matthias...understand what you are saying regarding the display
Dave
> Hi Dave,
> regards,
> Matthias
Dave
"GF-H:" => CF33
"GF-L:" => CF32
"Last:" => CF29
maybe there is a mix in the CF by Jacek.
Heiko
"GF-L:" => CF32
"Last:" => CF29
Heiko
Oh, my mistake, sorry!
But my proposal for CF32 and CF33 (!) is still topical.
Jacek
Jacek
Jacek
OSTC MK2 1175
OSTC MK2 1175
Maybe
"CF11:" --> "BSat:"
"CF12:" --> "BDes:"
(where 'B' is from 'Bühlmann') ?
Jacek
Maybe
"CF11:" --> "BSat:"
"CF12:" --> "BDes:"
Jacek
Jacek
OSTC MK2 1175
OSTC MK2 1175
Hi is it possible to have velocity in separate line instead of sharring with CNS
Maybe:
Velocity
CNS
ppo2
+1 aswell
Maybe:
Velocity
CNS
ppo2
+1 aswell
ujacek Wrote:
> "GF-H:"
> "GF-L:"
> "Last:"
+1
> "GF-H:"
> "GF-L:"
> "Last:"
+1
Scott
gorcio Wrote:
> JeanDo Wrote:
> > Arg... What is the whole gas config ?
> 1. yes, tmx lines are blue.
> 2. after switchinh NX50 and O2 off, the gas setup
> is following
> - (Gas 1) TMX 20/18 inactive
> - (Gas 2) NX50 inactive
> - (Gas 3) TMX 21/35 inactive
> - (Gas 4) O2 inactive
> - (Gas 5) AIR, active
Fixed. Thanks !
> is following
Fixed. Thanks !
[quote]Posted by: heinrichsweikamp ()
Date: January 07, 2011 11:24AM
Stellt ein, welche Funktionen im Tauchmodus mit der ENTER taste verfügbar sind. Sachen wie der Logbook-Marker oder das Leitgewebe sind für den Großteil der Benutzer uninteressant und können hier nach Bedarf aktiviert werden.
Gruss,
Ok, und danke für diese Info.
Zwei fragen, bitte.
- Für was ist das Logbook-Marker ? ( danke das es markierungen sind beim Tauchen, wo man im Log sehen kan )
Zweite frage, wie kann ich ein moment Markieren ?
Heute morgen wollte ich diese fonction probieren, habe im Tauchmodus das "Marker?" neben der Enter taste gehabt, im Menu Tauchmenu habe ich auch das " Marker" gehabt, und in dem DivingLog finde ich nichts.
MFG
Mike
Gruss,
Zwei fragen, bitte.
MFG
Mike
Hello all...
I think one other display bug:
In simulation mode (but I think also in dive mode), simulating one dive over 100mt, on the Max Depth value remain some dust at the end of the string, where before there was the decimal value (not used over 100mt).
Gaetano
Gaetano
Looking really good - well done.
Some quick feedback:
Decoplanner: any possibility of planning dives in the 99m - 120m range? Max is 99m at present
Decoplanner: can the CNS% be displayed beside the TTS please?
Avr. Depth: how can I turn it off?
Bailout: when going from closed circuit to open circuit bailout mode and then making an ascent gas switching on open circuit back to 6m and then wishing to go back to CCR mode (common strategy if there are electronics/cell issues), the computer assume the new diluent is the last OC bailout gas used. Perhaps choose the primary gas instead when going from OC to CC?
Low P02: is displayed in white rather than red like high P02. Perhaps red should also be used
Sometimes a * symbol appears after the gas mix in use. I'm not sure if its a bug or a feature but I can't deduce its meaning.
Thanks again for the great improvements.
Regards, Stephen
Regards, Stephen
Stephen McMullan
Dublin, Ireland
OSTC MK2 #850
www.technicaldiving.ie
Dublin, Ireland
OSTC MK2 #850
Guy's
I know its not a feature to be added for 1.80
At some point in time could you please add some sort of password to the CF's. (nothing too complex jus enough to make sure ther are no unitntended changes)
You wouldn't believe the number of people that stop me to see my computer. I usually are proud to show them and let them play with it for a minute or two.
However once they are done I have to check every single CF to make sure nothing has changed.
It would give most of us some peace of mind that the CFs havent been changed since we last configured them.
D
D
OSTC MK2 1394
+1
Sometimes a single * (although no better active gaz is to be changed), sometimes **... Seems to be buggy somehow.
+1
> buggy somehow.
Which version? Seems unlikely to me, this would be something we have noticed in our numerous dives already. Maybe you can post the Gaslist?
> buggy somehow.
> be
> > buggy somehow.
> Regards,
> Matthias
Dived yesterday with air + Nx 80. My buddy had Nx 50 and O2, so I programed Nx50 in 22m as 3rd gas, 100%@6m as 4th gas, both inactive. Last gas is Tx 14/56 in 0m, inactive.
I noticed a single * as I was finishing my deco in 5m. This morning, with the same gaslist, did a simulation dive and managed to have ** (have a look at the picture here).
MK2 V 1.75
> be
> > buggy somehow.
> Regards,
> Matthias
MK2 V 1.75
Coming back to the stopwatch - is it possible to request additional menu item for next release, Reset Stoper, apart from Reset Avg ? It would be really useful to be able to reset one without resetting the other ...
Kind regards,
