Page 2 of 2
Re: O2 fraction / O2 bruchteil
Posted: 27 Dec 2011, 10:39
by fortunato lodari
Hi!
it could be a setup option: "would you like to config decimal values in gases?"
than, who wish it will config it, others no.
es könnte eine Setup-Option werden: "Würden Sie in Konfigurationsdateien Dezimalwerte in Gasen wie"
als, die es wünschen wird Config es, andere nicht.
[fortunato]
Posted: 27 Dec 2011, 13:02
by tiefunten
No, it doesn't make any sense at all to calculate using decimals here. The analysers simply are not precise enough and it is not right to make precise calculations with unprecise measurements! But fortunately Matthias and Christian are engineers and will for sure know that...
Posted: 27 Dec 2011, 13:04
by Solodiver
The 2 Button issue cold be solved easily by changing the way entering the numbers to a digit based one: change the 1st digit, then the 2nd, 3rd, 4th and so on. Yesterday I had to change the clock on my OSTC from 19:05 to 18:02, guess how often I had to press the buttons!?
Back to topic: I think it is legal to have such a discussion and I'd like to see many more of them in here!
If there would be an option to define tenths for gas mixes I'd use it (knowing that there it would have very little effect to my run time). Every good analyzer is displaying tenths and I'm pretty sure I've a correct calibrated one.
Could also be a USP for the OSTC which leads some people to choose this unit...
Posted: 27 Dec 2011, 13:21
We are. But I don't think that this makes sense, sorry.
Posted: 27 Dec 2011, 17:08
It may make sense in theory but in this case I am whole heartedly with Matthias, pity fortunato didn't follow up his suggestion with more convincing arguments.
Posted: 27 Dec 2011, 18:51
by tiefunten
Matthias wrote:
"Hi,
Matthias"
Widersprichst du damit jetzt meiner Aussage, dass hier eine Rechnung mit Kommastellen keinen Sinn macht oder unterstreichst du diese vielmehr? Dein Kommentar liest sich irgendwie so, als würde mein Kommentar in deinen Augen keinen Sinn machen, was ich mir aber irgendwie nicht vorstellen kann...
Posted: 27 Dec 2011, 19:00
Ich sehe keinen Sinn Nachkomma-Stellen bei der Gaseingabe zu verwenden. Die erhoffte, zusätzliche Genauigkeit bei der Dekoberechnung ist vernachlässigbar.
Posted: 28 Dec 2011, 02:20
by tiefunten
Danke für die Erläuterung. So sehe ich das auch.
