New 2.70 firmware
Re: New 2.70 firmware
Just came back from holidays, flashed to 2.70 and testing tomorrow. But on the new CFs, I noticed that safety stop time is limited in time to 4minutes 10 seconds ? Strange number ... why not allowing only full/half-minutes increments and reasonable limit ?
Kind regards,
Gorcio, OSTC MK2 828
gordon mackie
I upgraded to 2.70 and was confused because I didn't know the gaslist was for OC and DIL menu was for CC, I changed my gas to 16/46 but it kept showing DIL as air.. I looked through the manual including the version on the website and couldn't see any mention of using DIL menu for CC or any change
I came across it by going through the menus and set everything up OK but it might be an idea to publicise it more or update the manual as I couldn't se anything obvious in the Forum or in the manual (which shows v 3.0 in the photo)
I hadn't spotted it before because I was diving air DIL
Or maybe I am missing something obvious... it wouldn't be the first time
46 years diving! Must be Doing It Right :-)
Ciro1982811 Wrote:
> heinrichsweikamp Wrote:
> > Ciro1982811 Wrote:
> > > Just a little try of the new firmware 2.7 in
> a
> > > 129mt 22' BT, Runtime 221min GF10/100 dive,
> on
> > a
> > The OSTC2 is not intend to be used in this
> depth.
> > > Everything worked fine.. except that maybe
> > 10/100
> > > is too aggressive, i was expecting almost
> > 15-20
> > > min more deco.
> > > And as a result, i got some pain in joints
> and
> > > head swinging for some hours after the
> > dive..!!!
> > You really should think about your dive plans.
> > And: If you really dive that aggressive,
> I
> > wouldn't tell anyone online.
> > There aren't any extra margins in the OSTC, the
> > red CF warning you may have noticed is there for
> a
> > reason.
> > Anyway: Have fun diving and add some more
> safety
> > margin in the future.
> > Cheers,
> > Matthias
> Hi mathias. that was the first time I tried to set
> GF in that aggressive way, because when i did
> extremely deep and long dives with 10/90 and with
> previous firmware, it seemed me that the last
> oxygen stops at 6 and 3 mtrs was excessively too
> long compared to previous used softwares.
> BUT that last one was the deeper and longest dive
> i ever made, and this time I had no reference with
> previous dives.
> With 10/100 i think the 36 to 9 mtrs stops was a
> bit too much aggressive and the oxy stops instead
> was right (almost 80 minutes). I was feeling right
> and strong till the end of the dive, so i decided
> that i was ok and went out of water. Little pains
> and head swinging begun 10 minutes later and
> persisted till the night. _I think that this was
> really near the limit, so next time i'll go back
> to 10/90 and plan longer dives!!
:D
> Anyway, here is some photo shots of the dive,
> excellent visibility, more than 40 mtrs at the
> bottom!
> [url=https://www.facebook.com/ciro.osimo/media_set
> ?set=a.10201649879078251.1073741828.1517378023&typ
> e=1]Gorgona island deep wreck exploration -136
> mtrs[/url]
> Cheers, Ciro.
The longer and deeper I go greater margin I select.... few minutes longer in the water wont harm me at all... I wouln´t plan that dive with less than a 15/80... Thats a personal choice and nothing to do with the OSTC, but still
> a
> on
> > a
> depth.
> > 10/100
> > 15-20
> > > min more deco.
> and
> > dive..!!!
> I
> a
> > reason.
> safety
> > Cheers,
> > Matthias
> previous dives.
> bottom!
> mtrs[/url]
> Cheers, Ciro.
crisostcn2
New 2.70 firmware
hi to all and sorry for my english
i have two little problem after update firmware 2.70 in italian:
1 - i have 1 2N and in simulation the first deco stop is partially covered by text, i cannot see the deep of the stop
2 - i also have 2 2C and in simulation you cannot set more the 9 minutes of bottom time (the display alway show 9 minutes even if you press the plus button). second problem is like the 2N, the first deco stop is covered by text
is there any solution?
Too long words in the Italian translation. We'll change that...
graham1272
woher kann man das source code von V2.70 stable download?
Vielen Dank!
Graham
Vielen Dank!
Graham
Pull the code here: https://bitbucket.org/heinrichsweikamp/ostc2_code/ and update to Rev. 733.
