Page 4 of 4
Re: New firmware 2.0 stable is now available
Posted: 22 Sep 2011, 15:10
by Dahab Boris
All,
OSTC 2n firmware upgrade:
Nice smooth upgrade..whilst the upgrade was in process the "w" of the weikamp flashed blue - nice.
The end "wait" message stayed for about 5 minutes and then the 2n rebooted OK.
Diving Log:
I seem to have lost my Custom functions. Reading in this thread, I think I can maybe save them to my PC by using the Diving Log program. Can I then reset (reload onto 2n) the custom functions when I update with the next firmware release from Diving Log ?
I am playing with the demo of DL and needed to update to 5.0.5 it seems before I could download any dives and to get Custom Functions I[3] and II [2]
Cfn 19 Says Default = 150 yet on my 2n is says Default=1.40 - which is the default ?
At last I can change my Customer Text via Diving Log - I didn't know how to do that with the 2n :)
Any tips appreciated
Posted: 22 Sep 2011, 20:15
by divinglog
Hi
Custom Functions will be resetted by the OSTC after a firmware update, that is by design and for safety reasons. I do not recommend using the "WriteToBinary" and "ReadFromBinary" functions in Diving Log to workaround this issue. It works, but you do that on your own risk and you might restore old values into new CF. If you do this, make sure to check every CF to see if it has the correct value. Resetting the CF is done by the OSTC to prevent incompatibilities between firmware updates (e.g. one CF has a different meaning after the update).
I'm not sure if it is possible to allow a CF backup and restore in a safe way. I have to discuss this with Matthias. Maybe I'll add a print or save-to-text function for the CF or a autorestore when it is safe.
Sven
Posted: 22 Sep 2011, 22:01
by tiefunten
As far as I know, the OSTC did not delete the CF's when upgrading from one of the 1.9x beta versions, as long as all CF's were within safe margins! At least none of my cf's were changed after upgrading and Mathhias told me this is right...
Posted: 23 Sep 2011, 08:52
by Dahab Boris
Sven,
Good point. Re new values. I would have thought though that safely set custom functions could stay as they were, and have new custom functions added, by the update.
Not a problem now I have noted which ones I have changed.
Tiefunten,
All mine were reset, but I went from 1.9 stable to 2.0 stable, not beta.
Posted: 29 Sep 2011, 12:03
by Willy
moin,
ne frage hab ich: ich hab die Version 1.90 in Deutsch auf dem 2N. Wenn ich jetzt das Update mache auf Version 2.00, ist diese dann auch in Deutsch?
danke euch
mfg und gut Luft
Posted: 29 Sep 2011, 12:29
by tiefunten
Wenn du das Update mit dem neuen Bootloader und den wenigen Mausklicks machst, hast du denke ich danach die englische Version. Soweit ich weiß, muss man andere Versionen noch manuell installieren - meine Aussage ist hier allerdings mit Vorsicht zu genießen, ich verwende nur die englischen Versionen (die Ausdrücke sind doch einfach kürzer und prägnanter...)
Wenn du mal in einem Thread weiter unten nachschaust, mehren sich allerdings die Verdachtsmomente, dass 2.0 einen Bug zumindest in der Anzeige der TTS hat. Leider hat sich da von den Programmieren noch keiner dazu geäußert...
Posted: 29 Sep 2011, 12:36
by Willy
mal sehen was die Programmierer dazu sagen?!
solange lass ich die 1.90 Version druff! damit bin ich bis jetzt sehr gut gefahren
Posted: 29 Sep 2011, 15:21
by sailor
Willy Wrote:
> moin,
> Deutsch?
> danke euch
> mfg und gut Luft
Hallo Willy,
bei der Version 2.0 gibt es in der ZIP-Datei verschiedene Sprach-Dateien.
Die Datei ohne Endung ist die englische Version.
Bei den anderen Sprachen hat die Datei nach dem Entpacken ein entsprechendes Länder-Kürzel im Datei-Namen.
Einfach die richtige Datei wählen und ganz normal installieren.
Beim Installieren gibt es keine Unterschiede zwischen den verschiedenen Sprach-Versionen, das geht alles mit dem neuen bootloader.
Schönen Gruß, Reiner
siehe weiter oben in englisch:
Re: New firmware 2.0 stable is now available Posted by: sailor ()
Date: September 22, 2011 01:19PM
after unzipping the V2.0 zip-file you have 5 different MK2-V200-stable files in your folder.
Plain is english, deutsch is german, espanol ist spanish, francais is french and russian is russian.
Choose the one you like for your MK2.
If you choose the plain file you'll end up with english.
For german choose the file "deutsch".
Edited 1 time(s). Last edit at 09/22/2011 01:20PM by sailor.
Posted: 30 Sep 2011, 11:31
by Willy
Hallo Reiner,
Super danke dir:)
Posted: 02 Oct 2011, 11:07
by Rainer
wie bringe ich die deutsche Version V2.0 auf meinen OSTC ?
Gruß
Rainer
Posted: 02 Oct 2011, 11:55
by Rainer
Alles klar, habe nun die deutsche Version überspielt.
Gruß Rainer
