Page 4 of 5
Re: Safety Stop/Sicherheits Stop
Posted: 25 Jun 2012, 14:13
The saftey stop is displayed between 5 and 3m (4.99m to 3.00m). The length is 3minutes. The time is reset when diving > 10m again. If the dive was a deco dive it's not shown.
Posted: 25 Jun 2012, 15:11
by Stu @ M Developments
[quote=heinrichweikamp]
Sounds absolutely perfect to me.
I would like to test this on Wednesday. If I download this firmware tonight and there are found to be any bugs, can I revert back to 2.21 again easily?
Posted: 25 Jun 2012, 15:15
Yes, you can downgrade at any time.
Posted: 25 Jun 2012, 15:22
Thanks, will try it Wednesday then. Great work, thank you.
Posted: 25 Jun 2012, 22:47
by wamchop
The only suggestion I would make would be to set the start threshold at 6m(5.99) rather than 5 to match up with other DC's that do call for a safety stop
Dave
Posted: 27 Jun 2012, 19:30
by Smiler1968
Hi, is the safety stop function supposed to work in a simulated dive? If so mines not working.
Jerry.
Posted: 27 Jun 2012, 19:43
by Smiler1968
> Regards
> Jerry.
I tried it again and it worked. Nice job.
Jerry
Posted: 28 Jun 2012, 10:41
by Bardass
not working with simulated dives
ok, tried it on 3 dives yesterday and it works fine, however, one annomaly is that it switches into safety stop at 4.99M, but switches back off at 5.1.
It does however still seem to count down, just dissapears off the display until you ascent above 4.9 meters again.
Apart from that, worked like a charm, but I would prefer it to perhaps switch into safety stop at between 6 and 5.5m and maintain the display unless we drop back below 6.5 perhaps?
Posted: 28 Jun 2012, 10:45
by cparsons
Strange - I tried this and mine doesn't work in a simulated dive either! Perhaps I will try again tonight - I am not going to use it anyway but am curious
Off topic but I would also vote for 10 gases for what it's worth
Keep up the good work :)
Posted: 28 Jun 2012, 11:19
Make sure to turn the stop on (CF65). I'll wait for more comments before I change the thresholds...
Posted: 28 Jun 2012, 11:32
Interestingly, when I looked at it, it said Default "Off" Current setting "on" and it wouldnt work. I changed it from on, to off, and back again, and it worked fine. I wonder if it was really defaulted to "off" regardless of what it displayed?
Posted: 28 Jun 2012, 11:33
[quote=Matthias]
thresholds...
Thanks for your time and efforts mate, very much appreciated indeed.
Posted: 28 Jun 2012, 11:41
by Uwe S.
habe einige TG`s im Simulator und im Freiwasser durchgeführt. Alles funktioniert einwandfrei. Bitte nur die Anfangstiefe auf 5,xx m ändern.
Gruß Uwe
Posted: 28 Jun 2012, 14:08
by Smiler1968
> displayed?
Stu, that's exactly what I did and it started to work.
I also dropped back below 5m and the safety stop disappeared from the screen. When I ascended again it came back on at the same point. Not sure if that's intended but wouldn't cause me any problems.
Safety stop starting at 5.99 might be nice.
Jerry
Posted: 28 Jun 2012, 19:31
Ok, I'll add some hysteresis in showing the stop. The stop time is reset when going below 10m. Above, the old stop time is resumed.
Posted: 28 Jun 2012, 20:57
by Bardass
It works !
But you need to turn CF65 on even if it's on
Matthias, you need to translate it in french :
CF65 : Palier de sécurité
Dive screen : PalierSécu
Posted: 28 Jun 2012, 21:24
by DiverM
Simply adjusting the countdown start depth to 6m would function as hysteresis and bring it to par with the Suunto and Mares implementation.
Posted: 28 Jun 2012, 21:57
by nakatomi
A 6m to 3m corridor for the safety stop would be perfect.
Posted: 29 Jun 2012, 07:41
by gorcio
Well ... 3 minutes time ... is not in accordance to CMAS/LIFRAS regulations in Belgium, nor is 3 meters depth. And so the computer has a function, which would be useless for people who are used to do 5'/5m. Feels like half-baked cake, even if I am not using it. Just my feeling and 3 cents.
Posted: 29 Jun 2012, 08:24
by Vortax
Computers sold in Belgium (Suunto, Mares, etc) give you a 5minx5m stop, or a standard 3min 6-3m stop?
Posted: 29 Jun 2012, 09:26
by gorcio
I do not know what they give, as I time my stops myself, and usually, I am doing deco stops rather than safety stop. Having said that - I guess it is not the computer, but federation rules one is supposed to follow. At least that's what I was taught.
My message was just a signal, that could be treated as something to improve if You decide to have such functionality built-in. I am not interested in discussing if Suunto is right, or if CMAS is right - just stating the fact.
Posted: 29 Jun 2012, 11:06
by swissdiving
Who ever said this was going to be easy!?
Posted: 29 Jun 2012, 11:20
by boefst
I don't think we are discussing a training-standard-compatible-dive computer here, but a simple Safety Stop like most computers have already. A guide to normal good diving practice when diving within the NDL.
The only difference is that it's configurable ON or OFF to suit the divers preferences.
Three minutes between 3 and 6 meters would be nice in my opinion.
Posted: 29 Jun 2012, 11:30
by Bardass
3m, 5m, 6m ...
3 minutes, 5 minutes ..
The most simple : use StopWatch
