5 extra Gases...
Posted: 19 Sep 2012, 20:38
For those who wait for the new beta, we'd like to introduce the five extra gases here. Right now I see two different versions:
1. Diluent and Bailout gases are configured in the Gas Setup. Switching between OC and CCR deco mode will "load" five gases into the gas setup. Switching back will reload the old five gases
2. Diluent and Bailout/OC gases are put into two different Gas setup menus. Gas Setup and Diluent Setup, for example.
I prefer option 2...
Re: 5 extra Gases...
Posted: 19 Sep 2012, 21:10
by DTR.Diver66
Hello Matthias,
i would like option 2
Posted: 19 Sep 2012, 22:15
by tiefunten
I would prefer option 2, too.
Posted: 19 Sep 2012, 22:32
Option 2 (tu)
Posted: 20 Sep 2012, 07:43
by Bardass
Option 2
Posted: 20 Sep 2012, 07:54
by scubatinoo
Option 2, but "Diluent Setup" only shown when in CCR-Mode...
Posted: 20 Sep 2012, 08:04
by Rob
Option 2
... and a description where in the binaries the data can be found.
regards
Posted: 20 Sep 2012, 09:06
by Stephane
Option 2 and when going back OC->CC, memorize the diluent used.
Posted: 20 Sep 2012, 10:22
OK... Expect the beta in mid-October.
[img]file.php?2,file=308,filename=OSTC.png[/img]
Posted: 20 Sep 2012, 10:38
by Touchwood
I would prefer option 2 as well. Also think the dil should only appear when in CCR mode as per Scubatinoo's suggestion.
David
Posted: 20 Sep 2012, 10:41
by DTR.Diver66
Hello Matthias,
it looks good. Still waiting for the next beta.
Regards (tu)
Posted: 20 Sep 2012, 17:33
by cparsons
Option 2 and diluent only when in CCR mode for me too :)
Posted: 21 Sep 2012, 09:11
by PeJo
Option 2 looks more promising, and with Dil gases only visible while in CCR mode to avoid mixup!
Sthephens wish also makes some sense that it should default back to same gas previously used if switching back to CCR mode from bailout!
Good work Matthias! (tu)
/Petter
Posted: 21 Sep 2012, 16:42
by sailor
if it defaults back on the same gas then we need another option to switch diluent gas.
Sofar the only way to switch diluent gas is to switch to bailout, switch over to another gas and then switch back to CCR.
I'm not an advocat for switching diluent but i think the option to switch diluent is required.
Posted: 22 Sep 2012, 01:03
by Vortax
Same here... Option 2, but only available in CCR Mode, to avoid configuring the OC gases in the bail menu by mistake
Posted: 22 Sep 2012, 20:17
by Escafandra
Option 2 as well. I agree with Vortax in the sense that they are only available in CCR mode.
Posted: 28 Sep 2012, 15:20
by smcmullan
Option 2 please. Thanks for doing this!
Do we still get a sixth gas in each list for configuring "on the fly" in case we end up with a gas in the water that is not pre-configured?
Cheers, Stephen
Posted: 29 Sep 2012, 08:48
by Eerikki
Good to hear we are getting more gas options.
I'm not aware how the other computers handle this but...
I see one logical challenge why we may need to stick with the current functionality.
You may want to have couple pre-set diluents and separetly several bailouts/decogases but...
You must keep the possibility to switch any bailout gas to be your diluent on fly.
One simple way is to just have more gases on current list and keep the logic as is except for having pre-set diluents available in separate menu. You pick the gas you use and it will automatically turn to gas-list as active gas #1
