Hello
I have just purchase OSTC. I found an anomaly with respect to the instruction book...
when I set a mix in the GAS SETUP and I want to set the depth of use, the instruction manual says to select MORE e the instruction manual says to select and set with MORE DEPTH + or - the depth of use, and the corresponding PPO2 is marked on the second line BACK.
In my OSTC there isn't BACK and consequently there isn't PPO2.
I have the version 2,50 but my friend has the previous version but he also has the same problem.
You know give me an explanation?
Thank's
Andrea
GAS SETUP
Re: GAS SETUP
do you have a picture ?
when you click on More ... on the screen "GazList", you should have this screen (see attachment)
marcasnow
Re: GAS SETUP
> attachment)
Hi Bardass
Yes, I have this screen but but in the instructions it says that there must be the BACK so I can set the maximum depth of use and PPO2 at that depth.
is it normal?
in attached the photo of the instruction booklet. I do not have the voice
regards
Andrea
> attachment)
Hi Bardass
is it normal?
regards
Andrea
Re: GAS SETUP
do not read instruction booklet !
it has not been updated for a long time.
use Depth +/- to change MOD on the screen and exit to go back
Attention : you don't need to change depth for the first gaz
first gaz need to be set at 0m
marcasnow
Re: GAS SETUP
thanks for your answer!
I thought that I had to turn some custom function but I could not find it.
to have this function would have been nteresting because so we have the END of the first screen set for the PPO2 that interests us
Andrea
Andrea
