New firmware 2.57beta
The new beta is now online: http://www.heinrichsweikamp.com/#/en/ostc_2n/firmware/
Changelog for this beta:
CHANGE: GF_hi default now 85% (CF33)
NEW: aGF: Alternative GF (CF67 and CF68). Can be switched underwater if CF69=1
NEW: CF67: aGF_lo [%]
NEW: CF68: aGF_hi [%]
NEW: CF69: Allow GF change (underwater)
CHANGE: Deco model default now is L16-GF OC (OC, GF-Deco)
WARNING: This update will reset Custom Functions!
Comments welcome (As usual) :)
This is how you switch between the two GF sets:
[img]file.php?2,file=330,filename=OSTC.png[/img]
DTR.Diver66
Re: New firmware 2.57beta
Post by DTR.Diver66 »
Hello Matthias,
thanks for the new beta. I tested the new aGF with the simulator and for me it is ok.
Great Work (tu)
Regards (:P)
maran
Post by maran »
Thank you very much for my request.
Post by Rob »
Hi there,
Custom Function Documentation in english and german adopted.
Servus miteinander,
Beschreibung der Custom Fungtions in englisch und deutsch ist ergänzt.
Grüße/regards
gorcio
Post by gorcio »
No change to safety stop configuration as discussed ? :-(
Kind regards,
Gorcio, OSTC MK2 828
Anyone can explain what this means
[quote=Matthias]
Post by Rob »
Thats easy,
if you go in the Reset Menu and do a "Reset CF, Gas & Deco" the Decotype is set to L16-FG OC.
rob
DTR.Diver66
Hello Matthias,
back from a nice 50m dive. The new feature aGF is working properly. Even the gray-out TTS and ceiling after gas change (until new plan is ready) is a good solution and also works ok
Fantastic work guys
@Rob
Hmmm..., Ok but I still don't understand what GF-Deco is. Is GF-Deco a new Decotype?
DTR.Diver66
Hello Hansjoerg,
no it is still the L16-GF OC. I think Matthias means that if you use this model you make deco dives.
Post by Rob »
@Hansjoerg
hi, OSTC supports the decotypes
ZH-L16 OC (thats the old default)
Gauge
ZH-L16 CC
Apnoe
ZH-L16-GF OC (the new default)
ZH-L16-GF CC
pscr-GF
Its just a change when you reset the Computer.
OK then, I look forward to the Official Release
Good Job! Thanks for your efforts!
This time all the CF settings were reseted? I did not expect this - so i did not take any notes before the update... So it would be nice - next time - if you can give an information like "this beta resets all settings" or something like that... Otherwise it costs me again "hours" to find my favorite battery color >:D<
Sorry, this was not intend. I added a warning above...
The default decotype was "standard" Bühlmann from the very first OSTC firmware.
This has now been changed. Even non-technical divers (We assume 50% of the OSTC users are rec-divers doing decompression dives from time to time) will benefit from this deco approach:
21min @ 42m on Air will result in:
Standard Bühlmann (ZH-L16 OC):
6m - 6'
3m - 15'
TTS: 26'
GF Bühlmann (L16-GF OC 30/85):
18m - 1'
15m - 1'
12m - 2'
9m - 4'
6m - 6'
3m - 17'
TTS: 36'
> above...
(tu) Thanks!
Thanks Matthias,
I think its a sensible change as it adds some conservatism. I've been diving on GF for quite a while now. I also support the change to 85.
DTR.Diver66 Wrote:
> Hello Matthias,
Can you post the dive downloaded with OSTCtools, please?
DTR.Diver66
Hello Matthias,
I will do that in a few days because I'm not at home right now. Is there a bug in the FW or what is the reason?
> is the reason?
Just curious, looking forward to the file...
Mike
Post by Mike »
Die GazListe Für diluent und PpO² einstehlung sind nicht sichtbahr mit dieser béta version.
MFG
DTR.Diver66
Hallo Mike,
die Diluent Gasliste funktioniert einwandfrei. Vielleicht solltest du das Update erneut aufspielen.
mfoll
Post by mfoll »
Hi Mike,
Same here with the french version: the whole "CCR setpoint and Gas" menu is black. English version works fine.
Matthieu
Mike
Post by Mike »
Ok, muss mal schauen hat mich aber gewundert das alle andere Menus eine nochmalle Farbe haben lol
Smiler1968
Post by Smiler1968 »
I've just updated to the latest Beta with a slight adjustment to the safety stop depth and its looking good. Now to go for a dive!!!!!!!
Cheers all
Jerry.
