Velocity Graph
Posted: 06 Jan 2013, 22:57
by Abyss79
After a couple of dive with the last firmware update, I notice the velocity Graph function. It look's nice but just today I notice that is not really a graph but just an Icon.
I mean, the graph doesn't go up or down depending from the speed of ascend.
I always see the graph full up to red also when the velocity is less than the alert level I've set.
I'm doing something wrong or somebody else notice the same?
Re: Velocity Graph
Posted: 06 Jan 2013, 23:03
by Bardass
No, it´s not a icône
Your value for CF47 ?
Re: Velocity Graph
Posted: 07 Jan 2013, 08:53
by Abyss79
I set CF47 = 10 and CF5 = 5
I'm aspetting that from 5 m/min It will show the icon with the first square filled
and when I reach 10 M/min it will fill the other boxes up to the red one.
But I always see them all filled. also when I just move up my hand just to read the data from my computer.
Re: Velocity Graph
Posted: 07 Jan 2013, 10:04
by Bardass
The graph is divided into 7 sections.
The first 5 sections are white, the ascent rate is lower than the configured maximum speed (CF47).
The sixth section is red when you reach the maximum speed.
The seventh section is red when you exceed the speed limit.
so your ascent speed was up to 10m/mn
Re: Velocity Graph
Posted: 07 Jan 2013, 22:08
by Abyss79
I will check again in my next dive, but I notice that just moving up my arm to see the computer was enough to shoe the 2 red square.
I will let you know
Re: Velocity Graph
Posted: 07 Jan 2013, 22:53
by reivilos
I've always been happy so far with the default values for these CFs. The ascent speed bargraph works fine - I usually ascend using a DSMB and a reel. But to be honest I haven't used 2.50 yet, only 2.21.
Re: Velocity Graph
Posted: 20 Jan 2013, 11:30
by Abyss79
I probably understand the problem.
I the difference between CF 5 and 47 is less then a certain value, I guess 5.
The OSTC is not able to divide the into 5 steps, because every step is less the 1.
And the result is that it always show the graph all filled.
This morning I dive with CF5 = 7 and CF47 = 9
When the ascent speed was 7, the speed was show in white and the graph was completely filled, When the speed was more the 9 the speed change to red and the graph was correctly all filled.
I guess to have the graph working properly I need to set CF5 to 3 or 5
and CF47 to 10 in order to have at least 5 speep between them.
Re: Velocity Graph
Posted: 20 Jan 2013, 12:10
by Peppe
> I will let you know
Did you have this problem during a normal and continuos ascend or just moving your arm upwards? in this last case, it's quite normal you fill all the blocks. The velocity ratio it's quite high moving just your arm.
Re: Velocity Graph
Posted: 20 Jan 2013, 17:50
by Abyss79
In both case, moving the arm up and also during a vertical ascending.
I understand the problem looking at the OSTC of mu buddy that had a different set of CF 5 and 47.
I think the problem is dividing the 5 blocks in less than 5 m/min.
Maybe the programmer could give us the right response.
Re: Velocity Graph
Posted: 20 Jan 2013, 18:26
by Bardass
Why don´t you use cf47=10 And CF5=5 ?
Or use only digit Ascent speed ?
Re: Velocity Graph
Posted: 20 Jan 2013, 21:33
by Abyss79
Now I have set it like this...
At the beginning was not usefull have it visoble from 5 M/min
But now with the graph I chaght in order to have the graph working properly.
