Page 1 of 3
New 2.61beta available for download
Posted: 07 Mar 2013, 10:58
We have just uploaded a new beta for the OSTC2: http://www.heinrichsweikamp.com/#/en/os ... /firmware/
It includes small changes and a bugfix for the "deko spike" issue:
CHANGE: Set default for CF64 (Color inactive) to 103 (light blue)
BUGFIX: Vault low_depth too
BUGFIX: Ascent to first stop in finer steps (Deko spikes)
Happy testing :-)
Grüße/Regards,
Re: New 2.61beta available for download
Posted: 07 Mar 2013, 15:26
by scubatinoo
heinrichsweikamp Wrote:
> Happy testing :-)
Thank you for the new beta!
As soon as my cold is gone... :)o
Posted: 07 Mar 2013, 15:28
by scubatinoo
> ...and a bugfix for the "deko spike" issue
What was the bug?
Posted: 07 Mar 2013, 17:56
That was this issue here: read.php?2,11119
P.S.: Get well soon :-)
Posted: 07 Mar 2013, 18:18
by smcmullan
Great response on the deco spike issue. Thanks for your efforts.
Posted: 07 Mar 2013, 21:40
But then other people are complaining about the OC Bühlmann algorithm...
...you just can't win.
Posted: 08 Mar 2013, 00:50
by smcmullan
I must have missed that. What was the substance of their argument?
Posted: 08 Mar 2013, 02:26
by Clownfish
Okay, when I looked at this earlier the link took me to 2.61 firmware. Now there is only 2.60. What has happened?
Posted: 08 Mar 2013, 15:43
by sailor
scroll down, open the "i" (information) beside 2.61 and scroll all the way down to the 2.61 zip-link
Posted: 08 Mar 2013, 16:48
by DTR.Diver66
nach dem Update auf die 2.61beta habe ich beim Start viele kleine weiße Pixel. Danach ist alles ok. Nach einem Downgrade auf die 2.50stable ist das nicht. Nach einem erneutem Upgrade auf die 2.61beta ist das gleiche wie beim ersten Update.
Gruß
Posted: 08 Mar 2013, 18:51
Kann ich mir gerade nichts drunter vorstellen, sorry.
Posted: 08 Mar 2013, 22:38
by Rob
Servus,
ich hab gerade die 2.61 beta (aktuell) installiert.
Das mit den weissen Pixeln kann ich nicht bestätigen.
Aber Matthias:
was mir beim überarbeiten der Custom Functions aufgefallen ist:
>> New in 2.60:
>> BETA Version - Do NOT use for diving!
>> CHANGE: Removed Mix type Icons and CF43
Das ist wohl eher CF41.
Grüße
Posted: 09 Mar 2013, 11:52
by Goose_66
Matthias,
thank you for addressing it so rapidly.
cheers
Fabio
Posted: 10 Mar 2013, 07:21
by wannabe
Hallo zusammen!
Meine Beobachtungen:
Die Pixel beim Start habe ich immer, habe die Reste von denen eingefangen, war nicht einfach, weil nur ganz kurz da.
Darstellung von einem Strich beim umschalten auf aGF- Anzeige, der auch beim weiterschalten stehenbleibt. Wahrscheinlich ist es ein deutsch-hex Problem.
Der Rest ist Euch bestimmt auch aufgefallen. CF41 ist inaktiv, aber an/aus ist noch aktiv und Batterieinfo zeigt nur aktuelle Daten, trotz vollladen zählt der Zähler nicht hoch.
Wenn ich noch was sehe, melde ich mich.
Danke, macht weiter so!
Posted: 10 Mar 2013, 07:22
by Clownfish
Was not there on Friday, but is now.
Posted: 10 Mar 2013, 07:54
by DTR.Diver66
das sind die Pixel, die ich auch meine. Die anderen Anzeigefehler kann ich nicht bestätigen, benutze die englische Version.
Gruß
Posted: 10 Mar 2013, 14:00
by tiefunten
Die Pixel treten bei mir nicht auf. Allerdings werden bei mir in der englischen Version auch nur die aktuellen Werte im Batteriemenu angezeigt. Ansonsten verliefen 2 Tauchgänge gestern problemlos.
Posted: 10 Mar 2013, 15:34
Ja, CF41 ist aktuell unbenutzt aber taucht natürlich noch auf.
Der Zähler zählt a) nur nach dem abziehen des Ladestroms und b) im Oberflächen- und Sleepmodus hoch.
Die Reste im Tauchmodus waren Reste vom text, der ist eine Spalte zu lang. Habe ich schon geändert.
Posted: 10 Mar 2013, 16:34
by wannabe
mit CF41 habe ich wahrscheinlich Blödsinn erzählt, ist mir bei den anderen inaktiven aufgefallen, habe nur nie hingeschaut. Sorry.
Mit der Batterieanzeige meine ich das: (Foto)
Es zeigt nur nullen und Livewerte. Habe schon im sleepmodus und Startbildschirm geladen, ändert nichts.
Gruß
Posted: 10 Mar 2013, 20:02
by tiefunten
@wannabe: das sieht bei mir identisch aus. Vor allem gibt es auch keine min und Max Werte mehr - war gestern im Walchensee, da müssten eigentlich um die 4 Grad hinterlegt sei, es stehen aber nur aktuelle Temperaturwerte im Menü.
Posted: 11 Mar 2013, 00:41
by reivilos
Hello all
With 2.61, when powering up I have this brief flickering of white pixels like snow. Then everything is normal thereafter. The new features are great.
I had not noticed this before with 2.50.
Just my €0.02 feedback, congrats to the HW team.
Posted: 11 Mar 2013, 07:28
by Clownfish
I tried to upgrade to 2.61 last night but ended up with a blank screen and non-responsive OSTC. I think what may have happened was that I started the upgrade and just as it kicked off, the OSTC went to sleep. Nothing I do wakes it up.
I have also tried the magnetic reset as described by Matthias elsewhere in this forum. COM4 was the correct port to select before. When I plug OSTC in the computer beeps showing that the device is connected.
  1. Connect OSTC
  2. Start Bootloader
  3. Put magnet near middle screw on back
When I do this, nothing happens. I have tried pushing update firmware after putting the magnet on the back but all I get is the following:
Connected to \\.\COM4 at 115200
HEX: 4 days old, INHX32,18Fcode+cfg, total=85392 bytes.
ERROR!
Not found!
Any suggestions?
Posted: 11 Mar 2013, 08:44
Please, be very careful with this magnet hard reset. It can turn your OSTC into a paperweight. Also, the magnet reset and update only work with the bootloader v1, not with the v2 you are using. The OSTC restarts when removing the magnet, so it needs to be removed in order to start the update process. As long as the magnet is in place, the OSTC stays in reset state and nothing will happen.
What was the log output of the update process when you installed 2.61?
Posted: 11 Mar 2013, 12:34
by Clownfish
Where is the log output found?
Posted: 11 Mar 2013, 12:35
In the bootloader "Messages" Window. Was there some kind of error message?
