Got my OSTC 2C two weeks ago. One question about the battery life: Are 40 hours the max. time or are 40h a realistic value?
Battery life OSTC 2C
Re: Battery life OSTC 2C
40h are worst case: Max. brightness, cold water.
On low brightness I have found battery life to be around 6 months having done some 50 dives avaraging 50 minutes per dive during that period. This still excludes the hours spent toying and demonstrating the OSTC on the surface....
In other words: Battery life is more than sufficient (tu):)-D
OSTC 2N #4807
I'm charging my OSTC only very rarely, maybe every 3 months or so, just for downloading dives. I'm doing 1-2 dives per week.
Battery run time is no issue in my mind. Don't worry
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
Under witch Voltage battery, is it recommended/necessary to make a full charge battery on 2N ?
Under 3.50V ? more ? less ?
A witch Voltage the charge is full, so I could stop the charge ? 4.10V ?
6RiL
6RiL
Charging stops automatically (Of course), recharge when the unit is at 50-70% or 3,5-3,6V
