OSTC 2N : How to replace Serial Number ?
Posted: 19 Jun 2013, 10:46
by 6RiL
English Version Below.
Bonjour,
Je souhaite remplacer l’affichage du numéro de série « OSTC 1234 » sur le mode surface par « OSTC 6RiL » de mon OSTC 2N V2.50. Quelqu’un saurait il m’expliquer où dans les fichiers sources je dois faire une/des modifications ?
Cordialement,
6RiL
_________________________________________________________________________________
I wish to replace in surface mode the serial number « OSTC 1234 » by « OSTC 6RiL » on my OSTC 2N V2.50. Someone could explain me how to do that in the sources files ?
Best Regards,
6RiL
Re: OSTC 2N : How to replace Serial Number ?
Posted: 19 Jun 2013, 16:23
Look at line 1076 and following in \code_part1\OSTC_code_asm_part1\output.asm
- or enter your stuff where it belongs to (The custom text) :)
Posted: 20 Jun 2013, 10:10
by 6RiL
No "output.asm" file in sourcecode250 ?!?!?!
I find "pled_output.asm" with something in L1033 like
OUTPUTTEXTH d'262'
I understand it refers to french_text.asm L402
TCODE .1, .1, "OSTC " ;262 OSTC
I am not expert in ASM code. If I replace L402 by
TCODE .1, .1, "OSTC 6RiL" ;262 OSTC
is it correct ?
Need I comment with ; L1035 to L1040 in pled_output.asm ?
6RiL
Posted: 21 Jun 2013, 10:54
by 6RiL
Ok, i found the file in 270 sources 8-)
I will try somethings :D
Posted: 21 Jun 2013, 11:53
by scubatinoo
One question: Why will you change the serial number? Is it a stolen OSTC? (:P)
Posted: 21 Jun 2013, 14:25
by 6RiL
It's just a first step to try to do a custom OSTC ;-)
Posted: 22 Jun 2013, 17:43
by 6RiL
oups, OSTC is locked on " Bootloader Please wait!" :S
Don't know if the cause is my custom program or not.
After download, OSTC didn't reboot.
Tiny BootLoader says
"Searching for PIC ..., Not found
ERROR!
Not found!"
Need help... How to "reset / restart" OSTC 2N ?
Prefer advise before use magnetic reset.
Posted: 23 Jun 2013, 19:40
Look here: read.php?2,4071
Use the bootloader v1 section. Instead of choosing to reboot the unit with the menu option, toggle the reset with a magnet on the backside of the unit.
Reinstall our official firmware, of course.
Posted: 24 Jun 2013, 09:47
by adrian-bluescuba
@9Ril
Sorry but this makes me a bit laugh.
Personalizing the comp by changing the serial number?? The good thing for Serial numbers are that they are usually unique. One number just for only You!
How wonderful and personalized !
cheers :-))
Posted: 24 Jun 2013, 13:26
by 6RiL
Magnet reboot do not works on my unit.
I tried with 2 different magnets, for same result :-(
When I apply magnet, OSTC don't change screen plot.
Always Searching for PIC ...Not found when write Flash
what's Wrong ?
Can i try something else ?
Thanks.
Posted: 24 Jun 2013, 13:37
Please post the bootloader log window output.
Posted: 24 Jun 2013, 18:52
by 6RiL
This is the log :
Bootloader for HeinrichsWeikamp OSTC,
based on TinyBootLoader, v.1.9.5 written by claudiu.chiculita@ugal.ro
http://www.etc.ugal.ro/cchiculita/softw ... loader.htm
Connected to \\.\COM3 at 19200
HEX: 2 days old, INHX32,18Fcode+cfg, total=86035 bytes.
ERROR!
ERROR!
Posted: 24 Jun 2013, 20:32
I'd say you're not resetting the unit (In reset state (Bootloader waiting for a new firmware), the screen goes black. Try a stronger magnet.
Posted: 25 Jun 2013, 13:40
by 6RiL
I have tried 5 or 6 differents magnets.
But screen do not goes black, always the red Bootloader
Some one suggested a loud speaker magnet. Is it necesseray to do with so strong magnet ?
Where on the back of OSTC is the magnetic recept ?
Thanks.
Posted: 25 Jun 2013, 13:51
> Bootloader
It's definitely not resetting. Do you have USB attached and powered? This kind of reset ONLY works when there is a USB cable attached.
(:DRe: OSTC 2N : How to replace Serial Number ?
Posted: 25 Jun 2013, 21:58
by 6RiL
Thanks a lot !
Near the end, I finished by try all magnets i found without USB connect.
Only the biggest magnet can reboot the ostc. I used a big stamp eraser for withboards. Others do not worked.
My program was not faulty... This one achieved well my (first) customisation.
But, before continuing modifications, i need to learn more about PIC and ASM !
6RiL
OSTC #[s]4917[/s]
OSTC #6RiL :D
Posted: 26 Jun 2013, 12:48
Good to know that it worked. And congratulations for successfully building your own release ;)
Posted: 26 Jun 2013, 14:46
by scubatinoo
i'm glad for you too and i really hope you'll survive your custom firmware >:D<
