:S still impossible to download dives from 2.7 octc 2c to jdive log
hello
the transfer of dives to jdive log still in error with my OCTC 2C firmware 2.7.
I have the correct port com, and the protocol MK2 1.91 to X.
the first dive of test of this new machine is downloaded and that's all, the second dive does not appear at all except on the diving computer.
I plugged the ostc 2n of a friend, port com 12 rtx... , no problem
can you help me ?
the message error after
moreover , what means on the screen of properties : "telechargement périodique " and "interval de chargement"
THANKS
can you help me ?
THANKS
Re: :S still impossible to download dives from 2.7 octc 2c to jdive log
Did you try already to create a new logbook first, and then start importing? Maybe something is messed up in your loogbook file on your Desktop-PC...
Can you explain me out to create a new loogbook ? wich icon to click on ?
File --> New or just press Ctrl+N
But Squalou, this is basic knowledge about using a software...
new logbook open.
Still same problem.
Only the first dive downloaded.
Still same problem.
Did you press F2 for downloading the dives? Then the programm reads your OSTC (you can see that on the display of your OSTC - so make sure before start downloading to turn on your OSTC!), then a window will popup asking you which dives you want to import... Choose all (mark them blue) and press "Import".
That's all i can help you.
Yes I did press F2. Screen of ostc is correct. There is no window popup asking me which dives I want. it imports the first dive and that's all.
Maybe you try to reinstall JDiveLog and update your Java Runtime Environment to the latest version...
jdive reinstall and java update.
Still same problem
Still same problem
Did you try to use Diving log, in order to test the connection ?
Find the the cause of this connection problem (Computer or OSTC).
Try Divinglog, Subsurface, OSTC Tools, OSTC Planner or similar.
Connection recognized with ostc planner.
I desintall jdivelog. I wrote to them, no real solutions.
I problem is..... I have 10 new diving in OSTC N2..... Dowload to PC (jdivelog) ....
Only 9 diving is transfer! That 1 diving is impossible download to Jdivelog??
2.7 problem?
2.7 problem?
jdivelog problem ...
absolutly no problem with Diving log, Ostc planner, ostc tools and FW2.7
No Problems here with JDiveLog and OSTC 2N and FW2.70
After updating macdive, no problem with Fw 2.70 and macdive either
______(+)______
0 o 0
OSTC 2n #6210
______(+)______
0 o 0
OSTC 2n #6210
Hi I've just bought a brand new OSTC 2N with 2.7 installed.
I've just one dive with and when i wanted to test the dive log backup I've faced the same problem with rather Jdive log and Subsurface.
I'm using a Debian Computer but I don't think this is the source of the problem.
When i read [quote] I problem is..... I have 10 new diving in OSTC N2..... Dowload to PC (jdivelog) ....
2.7 problem?[/quote]
I think there is a problem with dive index returned to computer during sync.
Laurent I can show you this strange behaviour when you'll come back from your holidays
Ok Florian
Essaie d'utiliser la version gratuite de divingLog
With the last couple of betas and 2.70, when I download using Subsurface, sometimes not only the newer dives download, but one more will be imported even though it already exists. All the dives are then recorded as 0 in the number.
Michael
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
Some news about this problem,
The sync protocol seams have change, has i updated subsurface to 3.1.1 the dive log download works well. In the changelog it is said [quote]support for current firmware in OSTC2 and OSTC3[/quote] at http://subsurface.hohndel.org/2013/06/s ... -released/.
I will open a bug to jdivelog to implement this new version ....
For information to linux user with both jdivelog and subsurface add your current user to the dialout group in order to not have to launch the program with the root privilege :
sudo adduser [your_username] dialout
I am now diving in Scapa Flow, Scotland. I have tried to download my dives three time using Subsurface. On the first two days I could only download the second dive of the day. The first is visible on the OSTC, but it does not get added to the logbook. I tried creating a new logbook and downloading, but every dive except the second last one was downloaded.
The second day the same thing happened. Today, I tried to download the first dive of the day after the dive (before the second one) but nothing downloaded. Tonight I tried again and got no new dives. The time and date is correct on both OTSC and computer.
The connection is obviously working, but something is wrong.
I have 2.70 on computer.
Any ideas?
Any ideas?
Michael
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
> one was downloaded.
> and computer.
> is wrong.
With the ostc2 transfer protocol, all dives are downloaded at once. So either you get all of them or nothing. So if the download succeeds and some dives end up in your logbook but others don't, there are only two possibilities: (1) there is a bug in the libdivecomputer library that causes the parsing to fail for some dives, or (2) there is a bug in subsurface that causes some dives to get dropped.
In both cases this is most likely and application issue, and we can probably better help you on the libdivecomputer and/or subsurface mailinglists.
Which version of subsurface are you using? There have been some changes in the latest ostc firmware that required an update to the libdivecomputer library (v0.4.1). This bugfix is only included in the latest subsurface release (v3.1.1), so make sure you are not using an older version!
Jef
> one was downloaded.
> and computer.
> is wrong.
Jef
libdivecomputer developer
Thanks Jef, I downloaded the new version (which I did not know had been released), deleted the dives I had already downloaded and it then downloaded all the 8 dives I have now done at Scapa.
Michael
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
Hi, the problem with jdivelog and fw2.70 maybe is fix. See this discussion on sourceforge forum
http://sourceforge.net/p/jdivelog/discu ... it=25#f375
bye
Stefano
bye
Stefano
Stefano
MK2 n.1414
MK2 n.1414
