V2.7 default diluent bug
mfoll
Post by mfoll »
I found a bug in 2.7 firmware. In the CCR menu, when you set the diluents, the default values are (i) not appropriate (ii) different for D1, D2... D5.
More precisely I have:
D1: 0/21 (which is not Air but 0% O2 and 21% He)
D2: 52/13 (why not 13/52 but 52/13???)
D3: 62/14
D4: 0/21
D5: 0/21
No problem for the classic gaz menu, all default values are 21/0.
Matthieu
Re: V2.7 default diluent bug
Hi Matthieu,
You have (most likely) upgraded from the 2.65beta, as well. Reset with "Menu -> Reset Menu -> Reset Gas, CF and Deco" and your defaults will be fine.
mfoll
Post by mfoll »
Thanks, it worked. I indeed upgraded from 2.65. I hoped I wouldn't have to reset all my settings... :(
