Failure ativazione OSTC2N
Posted: 18 Jul 2013, 22:26
by ling
Hello, today during a dive, the OSTC2N has not started, the initial screen has remained the same even in the bottom .. then it was off .... I tried to turn it back on for a couple of times but mostrasempre and only the splash screen and then goes off again as if it did not read the pressure.
What should I do?
thanks
Lino
OSTC2N 2763
Re: Failure ativazione OSTC2N
Posted: 18 Jul 2013, 23:01
Is it working when connected to USB?
Posted: 19 Jul 2013, 07:46
by ling
yes
everything seems to work regularly, even when I was underwater switched on and I could easily browse through the menu but it is not activated in dive mode
Posted: 19 Jul 2013, 08:35
Is CF00 on default?
Posted: 19 Jul 2013, 08:36
by scubatinoo
If you turn on your OSTC you'll find on the top left the actual pressure. For example 975mbar... As soon as you start descending this pressure should increase. If not then maybe something with the pressure sensor is wrong...
Posted: 19 Jul 2013, 15:51
by ling
CF00 >0,50m
show current pressure 505mbar
during the dive I brought it up to 8.5 bar but has not entered into dive mode
Lino
Posted: 19 Jul 2013, 17:04
by scubatinoo
Lino, 505mbar? Where are you living?
Posted: 20 Jul 2013, 11:24
by ling
yes ...yuo are right ..
.....i live in Naples Italy.... on the sea ...
..... of corse the sensor doesen't work.
Could it be reset?
Lino
Posted: 20 Jul 2013, 11:34
Try a reboot from the reset menu. But this doesn't explain why the unit did not switch to dive mode...
Posted: 22 Jul 2013, 19:39
by ling
Hi, Matthias and Scubatino
I tried to reset CF, Gas, Deco, Decodata and do the reboot but nothing happened always gives me the error of 504mbar.
What should I do?
thanks
Lino
Posted: 23 Jul 2013, 23:22
by ling
please answer me, if you must go in for service I would like to send it right away.
thank you very much
Lino
Posted: 24 Jul 2013, 07:58
Posted: 24 Jul 2013, 08:40
by ling
thank you very much
Lino
Posted: 03 Sep 2013, 13:19
by ling
hello,
sorry for the delay but I was on vacation and could not connect .....
endless thanks to Matthias for having admirably solved the problem of totally free replacement of the sensor in just 7 days from my communication ........ now my OSTC2N works perfectly.
best regards
Lino
