OSTC Change Request
Posted: 01 Nov 2013, 09:53
by garylegge
My previous query re the difference between the 2n and 3 tts on the deco planner for similar gases and profile remains unanswered. It is requested that the 3's deco planner is checked for accuracy against the 2n for a ccr deco profile using 20/80 gf's and the 3's software updated as required to align the two. The desktop planner also shows quite large differences. The only one I trust is the 2n.
Re: OSTC Change Request
Posted: 04 Nov 2013, 12:55
OSTC3 and 2 use the same deco routine. Using identical settings (And that's most likely the issue here) they output the same deco.
Posted: 04 Nov 2013, 16:46
by garylegge
> Regards,
The settings are as identically possible as it is to get them. Try running ccr on gf's 20/80 using 10/50 DIL with bottom time of 25 minutes at 75m on both the 2n and 3 planner. As I said before, there is a difference in the tts of at least 15 minutes. Give it a go and let me know what TTS you get on both the 2n and 3 using the deco planner. Either the routine is at fault or my 3 is faulty and would like to exchange it.
Thanks in advance
Gary
