OSTC3 Tool
Posted: 16 Jan 2014, 02:25
On a journey it is not easy to open the compartment battery with a coin because machining does not correspond, we risk to damage it especially when it is stuck with salt.
[left][/left]
On travel to take a large screwdriver isn't practical either,
[left][/left]
I propose (see 2 attached files - V1.04) a tool which makes it possible to open easily the compartment battery as well as the USB cover, (which can also be open with the Micro USB connector, but fragile for a blocking even with a weak force)
[left][/left]
This tool perhaps manufactured by you even, but it would be well to propose it included with OSTC3 or accessory.
[left][/left]
[left][/left]
[img]file.php?2,file=508,filename=OSTC3_Tool ... 04.jpghttp://[/img]
[left][/left]
[img]file.php?2,file=509,filename=OSTC3_Tool_1.5_-_V1.04.jpg[/img]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
